Question about RCA TH1101 MP3 Player
Convergence power supply board
Do you know where I can purchase a convergence supply board for a RCA P52927YX2 projection tv?
  • RCA Master
  • 8,617 Answers
Try www.partsstore.com they should have the board you need if its still available from RCA
Posted on May 25, 2008
How do i replace a convergence power supply on an rca 52 inch projection tv
The convergence power supply is the small narrow board which is held in place with a couple of screws. I am attaching a pic of the board yours may be slightly different 8_9_2012_4_22_22_pm.jpg
Aug 09, 2012 | RCA P52930BL 52" Rear Projection...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
RCA 52" Convergence Problem
Replace the convergence power supply. You can get the ITC222A convergence power supply board at the following link under RCA circuit boards.
http://www.tvrepairworld.com/
Jul 24, 2009 | RCA HD52W59 HDTV Projection Television
HD52W59 Convergence Power Supply
you can get the replacement ITC222 convergence power supply board at the following link. They have one at promotional sale price this week also under the sale items category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | RCA HD52W59 HDTV Projection Television
Convergance circuit board
I located the board at PTS Electronics. Mine was the digital convergence board.
A little pricey but did the trick. Recommend that if you do not know how to drain off the capacitors. Let theTV sit unplugged for 3 to 5 days to drain them down below a possible fatal shock level.
Recommend taking good digital photos for your reinstall if you have no schematics or real electronic experience. Priceless advise !!
Do not touch any settings to try and adjust without knowing the original factory settings. It will get expensive to have a tech readjust. Lots of time to adjust and the tech knows you were there. $$$$
Jul 04, 2008 | Televison & Video
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence...
since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Jun 24, 2008 | RCA Televison & Video
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
you dont need a new board just replace convergence ics that would be the way to go will cost you under 75.00 if you do it your self if you take it in it will cost you 250-350 depending on the shop
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence PCB probably not available....can you get me any #'s off the PCB or part # of STK IC or location # of convergence IC ??? ..................Should be worth fixing if I can get alittle more info....................T.
Note to mountain mom: You have a completely different
symptom ..............+ need service #.............
Try DVD ? all inputs ? cable box ? source to RF coax= on ch.3 ?..............................T.
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
RCA TH1101 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
