Question about LG Heating & Cooling
LG WINDOW AC MODEL: LWA-18F1PT1-AD42DM1 SHOWING Lo IN DISPLAY COMPRESSOR NOT GETTING ON
5 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: LG Window Air Conditioner
Check the repair shop for warranty on the work before you do anything else.
Posted on May 03, 2009
  • 252 Answers
SOURCE: LG Window AC Problem
send it back again!
hvac1960
  • 2133 Answers
SOURCE: i have i lg cassette
Ch-2 Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Helpful?
Posted on Jan 04, 2011
heatman101
  • 43501 Answers
SOURCE: LG Artcool Problem We have an
There is a problem with a sensor on the outdoor unit...the sensor is telling it that the outdoor coil is frosted over and it is trying to defrost it. If you leave it on does it eventually run or does it just stay is defrost mode??? The defrost cycle could take up to a half an hour...if it takes longer then it could also be a board problem... there may be a bad relay in the board...
heatman101
Posted on May 28, 2011
What is the minimum volts required to run 1.5 ton 5 star AC?
Low voltage will burn out all the motors Higher currents will ruin the start capacitor on the compressor and fan motors too. 220 vac is the minimum. You have to allow for inrush or start up current which most likely is the cause of the under voltage. You'll have to get a larger capacity stabilizer.
May 25, 2016 | LG Heating & Cooling
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
Apr 11, 2014 | Amana 45 Pint Electric Dehumidifier -...
WHAT IS THE TONS CAPACITY OF LG AIR CONDITIONER MODEL NO LWA12G19A1
1TR. You can easily find out with any model that indicates with name plate.
12,000BTU= 1 TR (12)
In your model LWA -12 is indication for 1 TR.
Is it helpful?
Dec 24, 2010 | LG Electronic Window Air Conditioner
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
LG 10,000 btu air conditioner
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
May 24, 2009 | LG Electronic Window Air Conditioner
May 03, 2009 | LG Heating & Cooling
send it back again!
Heating & Cooling Logo
66 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
