Question about Vodavi STARPLUS 2802 Corded Phone
How do I get my messages and change my voicemail message on this phone? I have no manual!
  • Carl Navarro
    Carl Navarro Sep 29, 2010
    Since a 2802 is just a phone, it has to be connected to something. What?
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
Changing my voicemail
Try Googling (uniden)(model)(manual) without parens for information.
Sep 04, 2017 | Uniden DECT 6.0 Cordless Telephone...
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
Need to change voice message HOW
access your voicemail, and choose the persoal options option, and you can then change your voicemail message, or choose a standard message with your number. good luck.
Nov 20, 2011 | Lands Phones
Need to change voicemail greeting message
Here's a link to the manual for you.
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/KALA300range.pdf
Hope this helps.
Mar 29, 2009 | Philips Lands Phones
Where is the voice record key?
Voicemail
Your network stores the voicemail messages you receive. To listen to your messages, call your voicemail number.
Note: Your service provider may give you additional information about using voicemail.
The phone calls your voicemail phone number. If no
voicemail number is stored, your phone prompts you to
store a number
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 22, 2009 | Motorola Mobility RAZR V3
Nokia 5185
In order to change your voicemail message you need to call into your voicemail system. Voicemail is not actually in the phone but a service where your calls are forwarded to. Most voicemail systems will play the main menu if you press the * key. One of them should be about a greeting. Check with your carrier for specifics.
Feb 03, 2008 | Nokia 5185i
Voicemail
Try going to http://www.reachcom.com/manuals/Panasonic_KXT7625_30_33_36.pdf where you can download the manual.
Cheers
AngelXena
Jan 10, 2008 | Panasonic KX-T7630 Corded Phone
I want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Oct 25, 2007 | LG Shine KE970 Cellular Phone
Vodavi STARPLUS 2802 Corded Phone Logo
27 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
