Question about Car Audio & Video
How do i put radio code in after changing battery it comes up safe in omega
  • 4,861 Answers
It shows SAFE because wrong codes have been entered previously
To restore LEAVE SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself
This could take an hour or two
Make sure you have the correct code
Posted on Sep 29, 2010
Radio in 7safe mode on Vauxhall omega
You need to re enter the code, ignition on, hold AS button till bleep, use preset buttons to enter code, press AS again. If you don't know the code DONT TRY TOO MANY TIMES as it will disable radio permanently after too many wrong attempts (not sure if it becomes scrap after 10 wrong attempts) in any event it will increase delay as you get more wrong.
Apr 02, 2014 | Radio Communications
The battery light in my opel omega is constantly red and i the dynamo makes 14volts so thats not the problem and my windows doesnt work and all the fuses are whole whats the problem?
check the earth wire under the battery they are common to go there and will cause this kind of fault., unbolt the 10mil nut and clean all the earth connections. do a proper battery removal first you will also need the radio code at hand as you need this fro the radio to work after this is all done. put ignition to number 2 ( when opening the doors first ) then turn off (0) then you have 30 seconds to remove the negative off the battery. only take the negative off, if you are going to charge up the battery make sure you put the live wire on first. now the battery is disconnected clean the earths under the battery. a wire brush etc will do the bolt sticking out but sandpaper is better for doing the copper connectors on the wires . if the wires are frayed then change the connection on a good clean part of the wire.
Oct 16, 2012 | 1994 Opel Omega
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
Is an Omega seamaster copy waterproof? (And this is not a Chinese cheap copy either. It appears very convincing.)
Generally it is safe to assume that copies are not waterproof although they be water resistant. Genuine omegas are sealed and compressed which is why a battery change at an authorised dealer (who will end the watch to omega) is approx £40.
Nov 30, 2009 | Omega Seamaster 2541.80 Wrist Watch
Radio display says SAFE and will not play music
You need your radio code its 4 numbers, you use your radio preset station button to change the # press the 1 station button till you put in your code then the # 2 preset station # then 3, then fourth preset. You should find your code in your service manual. when your code is in, press the + or - button on the station search, or refer to your manual. good luck
May 12, 2009 | 2002 Volkswagen Cabrio
Radio code for vauxhall corsa
The units anti-theft program was activated when the battery was disconnected. If you don't know the 4 digit code, try to contact the previous owner or most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Car Audio & Video
Radio in safe II mode
try disconnecting the battery overnight. that should put it back in safe mode 1.
Jan 09, 2009 | 1995 Audi S6
Vw golf .... alpha...... safe 2
"2 safe" means that your radio was in safe mode, and then the code was improperly entered 2 times. you either need to disconnect your battery and leave it for up to 4 hours (i've been told), or leave your key in the ignition for around an hour.
once it comes out of "2 safe" mode, then it will just say SAFE and give you the numbers 1-0-0-0. You just need to enter the 4 digit code (using your pre-set numbers 1-2-3-4 to change the numbers), then hold the seek > button and your radio should come on.
If you don't have the code, call VW. they'll find your code for free. they did for me. if not they'll charge like $50 or something.
Dec 24, 2008 | 1997 Volkswagen Golf
Vauxhall omega radio code
the radio code can be got from vauxhall 4 £29.99 and they will put it in 4 u not sure about a new radio lead though thanks jeza
Jan 28, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
