Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the fluidmaster valve as per directions and it did not help. I then replaced it and now it fill quickly, so that part is fixed but the bowl does not seem to have enough water in it (the tank is full to 1/2" below overflow tube) and when you flush it the flapper closes so fast it does not let the tank empty completly. I have adjusted the chain every way possible and even pulled it by hand all the way up and it still slaps closed before the tank is empty. So the 2 problems now are not enough water in the bowl and the flapper slaps closed to quickly. Remember this is a brand new toilet.
    Scholar:
  • 81 Answers
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Posted on Sep 29, 2010
Testimonial: "Thanks. Looks like I will be taking this one back to HD. I have heard that the Kohlers are pretty good, any thoughts on them?"
  • jeffseivers Oct 24, 2010
    You can't go too wrong with the Kohler Cimmeron
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
Slow filling toilet tank
Was taking over two minutes to fill. Problem was with fill valve.
To resolve problem either replace fill valve or remove the flow restriction. Here is how I done it.
Turn off water!!!!
Remove the supply line.
Inside of the fill valve is a rubber piece. It is about 3/4" in diameter by about 1" long. This rubber piece has become distorted after years of use. This has to be removed.
Believe it or not, use a corkscrew and thread it into the rubber piece that is located in the very lower section of the fill valve. You can't see it so you will have to feel. Pull it out.
Re-connect the supply line.
Turn on water.
Check for leaks.
Problem solved.
NOTE>>> This only works for American Standard fill valves.
Mar 01, 2012 | American Standard 4021 White Cadet 3...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Feb 22, 2011 | American Standard Cadet 3 Right Height...
My Cadet 3 toilet worked fine for a year. A plumber fixed a leak at the intake line. Since he left the bowl does not fill with enough water. This causes water to splash when I flush. The flapper has a...
thumbnail.aspx?q=411971824072&id=9a63c0e833b7cdbd3aca7d8622bc1566&url=http%3a%2f%2fwww.askmehelpdesk.com%2fattachment.php%3fattachmentid%3d14345%26stc%3d1%26d%3d1228681261
This is diagram of a typical toilet tank setup if the refill tube is not putting water into the flush valve as pictured the toilet will do what you have described.
Feb 12, 2011 | American Standard 4112.016 Cadet Toilet...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
Fills to slow. 40-45 seconds. Lowes representative says his fills in 4-5 seconds. This is what I am looking for.
There is probably some trash in the screen in the fill valve. You could try taking it apart and cleaning the screen, or just buy a new fill valve and install it. A new fill valve costs less than $10. It is an easy part to replace.
Aug 17, 2010 | American Standard Cadet 3 Right Height...
Toilet water valve does not fill water in the tank
Went to Lows and got a new fluid master water valve. Before I got any advice it's done.
Jan 13, 2010 | American Standard Cadet 3 Right Height...
Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | American Standard Home
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
722 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
