Question about Insignia LCDTV26 26 in. Television
Cost of part
What is the typical cost of a high voltage flyback autotransformer
  • fordcljo May 25, 2008
    thank you. Unfortunately, the brand I have is not listed. (Insignia)
    Thanks again
    President:
  • 2,712 Answers
They can range from $35 -$150, depending upon the make and model of your TV. Please see here:
http://servicemanuals.vstore.ca/index.php/cName/flybacks/osCsid/199d5276ed82c58d81153b195b52fbef
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson May 25, 2008
    That was just a sample page to show you the average cost of flybacks. You can do a general search for the model specific flyback on google.
I turn my tv on and and can hear it but no picture, then it turns off by itself and the red lamp light comes on
It is not a good idea for electronic products to be in storage for long periods of time. It is even a more poor idea to purchase used from a rental center; the result is more often than not a very bad experience.
With no picture, but working sound, it is a loss of the high voltage system. This is almost always failure of the high voltage autotransformer called the flyback and/or the HOT (horizontal output transistor) - which work together in producing the horizontal scan of the raster system and the high voltage to prduce the raster upon which the video picture is modulated.
The failure could very well be from HIGH temperature involved with the storage of the tv set.
The repair costs will be over $150 but not more than $300; depending on the exact parts that need replaced.
But: try the hard reset and the vibration/whacking test first to see if the moving business caused failures.
Hard Reset: Unplug for 4 hours, then try again. Do it twice.
Nov 27, 2008 | Televison & Video
No picture-rumbling sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
Jun 05, 2008 | Sony KV-32XBR250 TV
Blue TV Screen
May 24, 2008 | Televison & Video
High pitched whining
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Oct 04, 2008 | RCA F32650 32" TV
No picture and makes a chirpping sound
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
IrishDruid
May 13, 2008 | Televison & Video
Power surge knocked out both TV (same Model) also lost cable modem. Removed cover don't smell burned. No sign of surge on board or wires. I have repaired computers for 20 years but never until now tried to...
Hope that helps...Thank you for using FIXYA!
IrishDruid
May 13, 2008 | RCA 20F512T 20" TV
Humax lgb22drt
Hope that helps!
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
IrishDruid
May 05, 2008 | Televison & Video
Standy-by light blinking 7 times
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). This could have happened during the moving process. The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
Cheers,
IrishDruid
Apr 19, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV TURNS OFF AT DIFFERENT INTERVALS
How old is your TV?
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss. If the set is at least 10 years old this is typical and not worth repairing. If less, figure on replacing the flyback transformer.
Hope ya fix it!
Jan 06, 2008 | Samsung TX-R2735 27" TV
No power
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Cheers,
IrishDruid
Oct 16, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Insignia LCDTV26 26 in. Television Logo
21 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
