Question about Kitchen Ranges
Heating element on GE range stove
There is no heat produced on one heating element. All others work. I have tried a new heating element but still no heat. Someone told me that I would have to replace the range stove. Any suggestions would be much appreciated. Thank you.
R/
Paul
    President:
  • 1,314 Answers
If its a plug in coil type element then you need to check the terminal it plugs into to see if its burned or the connections are spread or replace the switch no you dont need a new range
Posted on May 25, 2008
My scholtse glass top won't work with my utencils
THe glass top is just that, glass! If the elements beneath it are not producing enough heat your utensils will not cook. Pull off the glass top by removing fasteners (either in the front of the stove or under the back panel of the stove). Then, turn on each electric burner to see if it turns RED hot. If not, wait till everything COOLS and reseat each heating elememt and retest those that failed. If that doesn't solve the problem, you can buy heating elements at Home Depot or other stores...
Nov 12, 2012 | Kitchen Ranges
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
The oven does not heat up on my GE Spectra XL44 but the broiler and stove work fine.
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
Oct 30, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Kitchen Ranges Logo
134 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
