Question about Bburago Citroen C6 Diecast Model
I have a citroen picasso and the engine fan keeps running even after the engine is turned off. THe only way to stop it is to disconnect the battery. but it starts again the minute i reconnect the battery
    Champion:
  • 249 Answers
Need to know what ecu your vehicle runs on, sounds like a open circuit on etc. If you unplug it the same happens, or give me your engine.e code so I can the running system to confirm
Posted on Mar 27, 2012
  • 600 Answers
I is most likely a stuck relay, have a look in the handbook and locate the cooling fan relay and pull it out, the fan should not run now (I have seen wires shorted together doing this) give the relay a sharp tap on a wood surface and re fit, if it clicks and the fan comes on then it will be the sender that has to be changed.
Posted on Jan 12, 2011
When indicator light shows both arrows not single
CITROEN XSARA PICASSO questions and answers
www.roadtestreports.co.uk/cars/citroen/xsara-picasso/qanda/
Results 1 - 40 of 914 - Help and advice on everything CITROEN XSARA PICASSO. ...fitted.. citroen do two variants.. one with pads and one with shoes. ... Hi when I turn side lights on my indicators start flashing and ... Both bulbs are OK, but light is of. ...our 2006 Picasso just wondering does yours go past 50mph if not then it ...Missing: arrows
CITROEN questions and answers - RoadTestReports.co.uk
www.roadtestreports.co.uk/cars/citroen/qanda/
One more thing the clutch is nearly gone but this wouldnt cause the noise. ... My horn keeps going off randomly in my Citroen C1 hatchback car ( 2006 ) when I ..... MyCitroen Xsara Picasso`s air bag warning light comes on but not all of the time. .....box Citroen C3 - two boxes will show, both fit, choose the £48.9 one + £5.00 ...
Jan 11, 2016 | 2006 Citroen Xsara Picasso
Citroen picasso faults
You can try using Lexia 3 , it may help you to solve the problem!
May 17, 2014 | 2001 Citroen Xsara
Fan belt broke on picasso wont start now
if fan belt broke
that means alternator not charging battery so need to jump start the car as battery is flat and will not be charged till fan belt is on.
Feb 12, 2014 | 2001 Citroen Xsara Picasso
Citroen xsara picasso 2005 tailgate keeps unlocking
lock catch is dirty. clean it with brake cleaner and then spay wd40
Jul 07, 2013 | 2001 Citroen Xsara Picasso
Whats wrong with my radiator cooling fan citroen 2000 picasso
fan relay may be bad,or fan has just gone bad
Jul 04, 2013 | Toys
07 petrol citroen xsara picasso judder/loss power after 1/4 mile from cold
service the car, put correct engine oil in it and also change gear box oil
Apr 03, 2013 | 2007 Citroen Xsara Picasso
Picasso heater blower not working
Hi all. Yes this is a very common issue. 2 distinct issues in fact are common with the aircon.
1 you get fan on certain settings only. This is the resistor gone and johnjohn2 has identified the fix for this above. This is usually (although not always not intermittent and so you will usually lose all other settings over night and they don't come back
2 you get no fan activity at all. This starts to happen intermittently and then gets more frequent until the fans won't work at all. The fix for this is expensive through Citroen but cheap if you get the part off ebay. It is the ignition switch cable which has a fault. A very common issue. You need to remove the ignition switch and replace the cable from it. Work is not long but plugs can be tight and fiddly.
here is the link for the part
http://www.ebay.co.uk/itm/Ignition-Switch-Cables-Wires-PEUGEOT-206-CITROEN-XSARA-PICASSO-Lock-Barrel-Plug-/121038091531?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6eb50b
good luck
Oct 18, 2012 | 2001 Citroen Xsara Picasso
Hello Citroen Picasso Diesel 8 year old, had it since new. Fault recently started. Engine starts OK. While manoeuvring forward and backwards in driveway sometimes get a warning beep and ignition light flas...
It could be the brushes in the control box on the back of the alternator, the vibration on tickover might be enough to bounce the short brush and cause the lights to come on. Try and find a garage or auto electrician who will change the control/brush unit for you.
Oct 25, 2009 | RTO Alternator/Battery Tester
Citroen picasso keeps cutting out twice a week on acceleration
Sounds like an air leak or the tank pump cannot keep up with demand (the supply pump in tanks do give trouble (a pressure gauge between tank and engine would tell, make sure it is visable when driving, I used to tape it to the bonnet with masking tape.
Jun 23, 2009 | 1987 Peugeot Liberte
Bburago Citroen C6 Diecast Model Logo
958 people viewed this question
Top Bburago Toys Experts
Are you a Bburago Toy Expert? Answer questions, earn points and help others
