I am getting an error code on my HP Photosmart D5160. It is a long one so here I go. -003311FF44ddd6--. Now, those ones could be a capital I, but I am not sure. The red exclamation make is lit constatly. The power button it lit constantly. I have done everything I know to do according to the HP website; reset, unplugged, looked for paper jams; etc. Please help - I need some direction? Thanks for your help, Allison
  • 1,606 Answers
I gave HP some negative feedback on their failure to provide an error code lookup on their support page for this printer. In the meantime, did you hear any unusual noises from the printer the last time it ran, or do you hear any when you turn it on? If you do, try to locate where in the printer they come from, and inspect the components there for cracked plastic gears; loose springs, etc.
Also (this is a shotgun solution), locate the clear plastic ribbon behind the ink cartridge carrier. This has very fine vertical stripes marked on it; it's used for optically tracking the position of the carrier. Dampen a cotton swab with isopropyl alcohol (used to make rubbing alcohol) and gently wipe this ribbon along its entire length using vertical strokes. Pay special attention to the right end of the ribbon; this is where ink spray is most likely to get on the ribbon, ink here can cause a cartridge homing error.
Another possibility is an excessive buildup of waste ink in the cartridge parking area. Open the printer as you would if were going to change the ink cartridges so they are away from this area, then unplug the power cord on the printer (you'll need to do this to clean the right side of the optical ribbon anyway). This may give you access to clean out the ink from the cartridge storage section, but you may have to partially disassemble the printer to really get at it. This will be a messy job, so have plenty of rags or paper towels on hand, and isopropyl alcohol as well for solvent. On some printers, there is a waste ink tank with an absorbent pad under this area; when it gets full the printer shuts down with an error. Usually (depends on model) this is a major pain to get out, but it cleans up with soap and water and can be put back in when it's dry. There may be a secret code required to reset the ink tank error when this is done.
Posted on Jul 15, 2017
  • 35 Answers
SOURCE: Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Posted on Sep 20, 2007
SOURCE: power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
Posted on May 10, 2008
melnavz
  • 1226 Answers
SOURCE: HP Workstation xw4400 Beep Codes
Unplug all the computer from the wall outlet and then..open the CPU (computer system) Try to remove the memory and then clean and insert in again and then test
Hope this an initial help,
tell me what so ever happen.
melnavz
Posted on Sep 30, 2008
kcmetal9901
  • 102 Answers
SOURCE: HP C4180 says carriage jam but no jam and tried everything
uninstall your printer and then reinstall
Posted on Oct 31, 2008
SOURCE: Error code E94 paper jam
E94 errors - paper jam can be cleared by removing battery back-up and replacing them. The error appears to be retained in the memory.
Posted on Feb 08, 2009
HP photosmart printer error code 0x61011be5
There problem with printhead you have to change it , with new one
Here how to change the print head :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01822764&lang=en
Mar 22, 2013 | HP Photosmart Premium C309A All-In-One...
Sir am geeting problem in hp all in one
Hi
Please refer the weblink provided below for the error code and work carefully with the printer to get the issue resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01815748&cc=us&lc=en&dlc=en&product=1153494
This should fix the issue.
Jan 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
I get error codes 0x887ffd78 & 0x6b900004b when I attempt to print a document. -hp photosmart 2710 -wireless network
there something wrong with the installation of your software printer...
install again so that the error appear will not come back more
Oct 19, 2009 | HP Photosmart 2710 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Get a Capital letter
As you scan through the letters capital letters should eventually appear.
Jan 21, 2009 | HP Photosmart C6100 All-In-One Printer
I have an HP D7360 printer. I receive the error code 0xc05d2281. can you help?
I have a HP Photosmart C6180 All-in-One printer. When I try to print I get error code Oxc05d2281 on the printer scren. I have replaced all the carriages with new one. Please tell me how to fix this problem.
Thanks,
Estella
Jul 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart
try this site
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 07, 2007 | HP Photosmart 2575 All-In-One InkJet...
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
