Question about Dell Inspiron 6000 Notebook
Audio I have no sound. When I try to run Itunes, it says there is an audio configuration problem. On fixya, it suggested reinstalling sound drivers. How do I do this???
    Scholar:
  • 187 Answers
Go to the Device Manager (right click My Computer > Properties > Hardware), and locate "Sound, video and game controllers". Right click the audio device and click Uninstall IMPORTANT: Make sure you have a copy of the setup for the drivers. http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=INS_PNT_6000&os=WW1&osl=EN
Posted on May 25, 2008
Error message when logging into ITunes and audio will not play. "Itunes has detected a problem with your audio configuration. Audio/video playback may not operate properly." I have searched...
you should uninstall audio drivers then install the updated drivers for your audio.
then un-install iTunes and its all apple product using revo un-installer. that will ask to remove all the registry so while uninstalling the programme select all and delete them.
then download and install latest iTunes.
it will start working.
if it doesn't you can restore your computer to a previous date on which your itunes was working properly.
to do so.
click on Start >>>All Programms>>> Accessories>>System Tools>> System Restore>> Select the Date and Restore your Computer.
Enjoy!!
Jun 28, 2011 | Apple iTunes
The sound stopped coming after i formatted the machine
It will, you need to install the audio drivers.
Just go to the makers website, click support and download your driver.
Or tell me what system you have, and i will find your drivers
Sep 04, 2010 | Computers & Internet
No sound at all..
I found several things to check about this issue.
First of all, make sure Windows Audio and Windows Management Instrumentation Services are running. Steps:
  1. Go to start -> run. If your keyboard has a ‘windows key’, which looks like the windows icon and is often located next to ctrl/alt, you can get away with pressing (and holding) this key, and tapping the ‘r’ key. I use this shortcut almost every day. On that note, windows-key+e I use even more- try it.
  2. type ’services.msc’, without the single quotes. This opens a list of the various services running on your computer.
  3. Make sure iTunes is closed.
  4. Locate “Windows Audio,” and see if it’s running. If it is, the status will show ‘Started’.
  5. No? Well guess what, iTunes needs this to be running in order to communicate with your audio device. Start it. There’s a link to start it along the leftmost column. Once it’s started, find a blank area within the services window, right click and hit refresh. Or just tap F5. Has the service died? If not, skip to step 7.
  6. The service died, didn’t it? Look for a ‘Windows Management Instrumentation’ service. This needs to be running for Windows Audio to be running, even though it’s not listed in the dependancies. Fire it up, then fire up Windows Audio.
  7. Fire up iTunes, and enjoy.
Secondly, you can open Control Panel and uninstall and then reinstall QuickTime. You can download QuickTime at this URL: http://www.apple.com/quicktime/download/
Third, you can try to reinstall iTune and allow any settings about playback and audio configuration with iTune during that.
Hope those helps.
Jul 09, 2010 | HP Compaq WF1907 Monitor
NO SOUND ON DELL INSPIRON 6000 PLEASE HELP!
Try to uninstall and reinstall the Itunes c could resolve the issue.
Apr 01, 2009 | Dell Inspiron 6000 Notebook
Audio configuration problem
I would suggest u to the restore your computer because somebody or you might uninstall the sound card software by mistake. Go on start then all programs then accesories then system tools and then restore
Mar 17, 2009 | Microsoft Windows XP Professional
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
you may need to download a audio driver for your computer,, or manually install it by goin to the sytem device manager,,,good luck
Oct 06, 2008 | Computers & Internet
When i open up itunes it says audio configuration problem, and i cant hear no music or sounds i think i have deleted the file that runs the audio cofiguration how do i fix it?
Hi there, uninstall the soundcard in the System Properties--> Device Manager section of Windows XP/Vista (Press the Windows Key & Pause/Break)
Next time you reboot it will reinstall the drivers for you, that should help.
Regards
Chris
Jul 21, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Creative sound blaster x-fi xtreme audio
Windows closing slow means you have a bunch of program that are running in the back ground. Windows has to close each before the system can shut down. To see just what is running in the back ground. Allow windows to completly finish opening. Click the start button, click run. In the window type, msconfig & click ok. System Configuration Utility window will open. Click on the Startup tab. Now you can see just what programs are running in the back ground.
Adding memory can also help speed up a slow pc & keeping the system clean by using the two programs listed next.
First. Run disk cleanup, a windows program found in system tools. Than run Defrag also found in system tools. Restart the pc when finished. This should help your system to run a bit better.
If you have the CD that came with the sound card uninstall the software through Add/ Remove programs found in the control panel. Restart the pc. Reinstall the drivers from the CD & try opening a few programs. Open & run the program your using to play music. Any better? If not try using another music program like iTunes a free download found here. http://www.apple.com/itunes/
You can also try the drivers from creative they may be newer than your CD here: http://us.creative.com/support/downloads/welcome.asp?action=next
Enjoy!
Please vote...
map9966
Jan 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
No audio when i try to play tunes in itunes
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 23, 2007 | Adobe Photoshop 7.0 for PC
Dell Inspiron 6000 Notebook Logo
127 people viewed this question
Alun Cox
