Question about Motorola Mobility RAZR V3xx Cellular Phone
V3xx signal loss
My V3xx RAZR has lost signal. I bought an external antenna that plugs into the plug on the back of the phone. After having it plugged in over the weekend and after unplugging it from the external antenna, it quit receiving a signal. What have I done?
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service shop and have them replaced the antenna that is located on the phone's main-board.
Posted on Aug 18, 2008
I am using Razr V3XX
find a japanese kid at a local college to fix your phone as long as they can read japanese
Jul 03, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full...
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Oct 13, 2008 | Lands Phones
My razr v3xx keeps searching for network
maybe the antenna is not in correctly...you should take the phone to a mobile shop and have them check it over for you.
Aug 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
My Razr V3xx won't turn on
I've had two RAZR phones die in the same way. The first time I went into Cingular to see if they could fix it and they told me it was a goner. It was replaced under warranty. I had one die that way a week ago as well, and got that replaced. The first time, I lost every number and address I had in it. This time I had it all saved to the SIM card so I could upload it to the new one. Sad fact is, that phone is most likely done for and the numbers are lost.
Jul 29, 2008 | Motorola Mobility RAZR V3
New razr frozen
I have read somewhere that if you had waited untill the phone completly dried out you would have had a chance of it working.But as I see it now the phone is useless.
Mar 04, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx I-mode
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone.
Regards,
David M-G
Feb 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
External antenna
try teking the phone and have the antenna replaced or service that should correct any problems that you may have.
Feb 01, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3xx not powered on
you need to charge a phone over night for the battery to fully charge and have a memory
try plugging in as charging and turn phone on by holding the red button down for a few seconds on the right hand side
Oct 11, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 No signal (bars)
I had the same problem with my phone- i got a cheap generic battery to replace the old one (which wasn't holding a charge for a full day, at that) and then i lost all signal, basically. I tried what scm_pa said he did - charged my old battery up, with the phone off, till the charge was complete- turned the phone on, and voila, reception!
Oct 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
159 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
