Question about Pride Jazzy 1113 Power Chair
My mother-in-law has a jazzy 113 for about 6-7 years and the 2 wheels broke in half. How can this happen when it is a solid wheel? Please let me know what to do. Its the back wheels.
  • 692 Answers
Liz First Did Medicare buy MIL's chair? If they did contact me @ lennieg2000@yahoo.com and I'll give you more info. Now after that long the tires get brittle and usually need replacement. You can contact the provider where MIL got her chair and have them get the caster wheels for the chair. Hope this helps
Posted on Sep 29, 2010
OK, mother in laws 2001 escorts xlt rear end making roaring noise I need to know how to r&r step by step can someone please help
Difficult to diagnose sounds, but most likely to be wheel bearings. You need to sit in the back with the windows open and move side to side to see where the noise is from left or right.
Not a difficult job, but a tip, when you put the new wheel bearing in, tighten the centre nut down hard until the wheel locks up solid. Then back off by the number of degrees as specified, usually a quarter turn if my memory serves me correctly. I did this job in 1975. If you don't do this, the bearing becomes loose and wears out very quickly. Also use LOTS of grease pushing it into the roller bearing cage.
Google
year make model replace wheel bearings
Nov 24, 2016 | Cars & Trucks
How do you adjust the front springs s0o that the rod wont bnd and break?
Pride Mobility Jet 7 (Power Wheelchairs) - USA Techguide
www.usatechguide.org/itemreview.php?itemid=929
13 posts - ‎11 authors
Anti-Tip Wheels 6&8221; solid; front-mounted • Suspension Limited. ... get either aPride Jazzy, or a Jet 7, you'll be very happy, as long as you can afford a lift ... If youdont, the charge keeps going down, and will not ever recharge back to the ... These products need to be charged about 8 hours a day after usage, so its better ...
Dec 01, 2015 | Pride Jazzy 1103 Ultra Standard Power...
My pride jazzy electric powerchair will not unlock on one wheel, it only has one lever in back to release both wheels
Your jazzy chair should have 2 levers. There is a lever for each wheel. if the other wheel does not have the lever, then you are missing the lever that would release the wheel. Have a local tech look at it and they may be able to get the parts needed to release the other wheel.
May 09, 2015 | Pride Mobility Products Health & Beauty
Traction is erratic - directional control is a problem
sorry but i can't see how's that a fault, can you please explain in more detail ?
Regards
Dec 15, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I just gave my mother in law the jazzy 1103 ultra power chair... when you put it on.. the lights flash and the chair creeps along.. it happened all of a sudden.. it wont speed up.. this was donated so I...
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Sep 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy chair pulls left
Since each drive wheel has it's own motorand both are controlled by the joystick you can narrow it down to the motor opposite the side it is pulling to (probably not the joystick programming if it was working before). However, there may be another answer: if your home has a lot of carpet, or worse a dog, check where the wheel mounts to the drive motor and clear anything that might be wrapped around the wheel axle into the motor, similar to what happens to a vacuum cleaner brush wheel.
Sep 13, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Sep 06, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Removeing Jazzy 1170 wheel
Yes, you need a puller:
1 Remove the Nylock nut and washer (3/4 socket)
2 Pull the wheel with a 2 tooth wheel puller
Oct 29, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Jazzy 1113 Power Chair Logo
116 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
