Question about Refrigerators
Frigidaire refrigerator leaking water inside refrigerator
My frigidaire refrigerator is leaking water inside the refrigerator part from the top of the refrigerator. i don't know if it is coming from the freezer or what. is there hoses or something that could have came off that would be causing it to leak from the freezer down into the refrigerator?
  • 6 more comments
  • Lramirez May 27, 2008
    I have the same problem, but my hoses aren't hooked up. Is the fridge condensing, freezind and then thawing?
  • Anonymous Jun 09, 2008
    yep, mine is a Kenmore and having same problem. I figure it may be the compressor
  • aracriat Sep 01, 2008
    I have a FRIGIDARE side by side fridge with water and ice dispenser and EVERY time I open the left freezer door water leaks out from the bottom edge/frame of the water/ice dispenser compartment.....PLEASE HELP!
  • Anonymous Dec 28, 2008
    My auto defrost fridge has a water leak inside and i could see the the water trace from the freezer. Is the problem is in the drain tube ? whrere to find and how to fix? ta
    Sue
  • mulherndana Feb 26, 2009
    The inside of my fridge is leaking from up inside right under the freezer. There are two openings and water is constantly dripping from both. I have an ice maker, does that have anything to do with it? It is a Fridgidaire.
  • Anonymous Apr 12, 2009
    I have a Westinghouse RT190G refrigerator with a top freezer and no ice maker. It leaks water just below the freezer from a plastic "vent". Its about 20 years old but in very good shape except for this problem. It leaks out about a cup of water in about 48 hours.
  • jmm11_2000 May 06, 2009
    My frigidaire FRT21P6CSB0 is dripping a gel / melted styrofoam from the top console in the fridge. It still runs but no longer cools. Any ideas?
  • aguilarmama May 11, 2010
    Along with WillMac's EXTREMELY HELPFUL advise, my husband removed the freezer tray, held in place by 2 screws, on the bottom of the freezer. Ours was completely lined with like 2 inches of ice, which had been slowly melting and leaking into the fridge.
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
I had the same problem, water on shelves inside the refrigerator .
I took apart the back panel in the top freezer compartment.
What I found was a build up of ice in the port that feads the cool air to the refrigerator. Thaw ice of course and installed back panel. I fixed this problem with a little trial and error. Because there was ice in the port feeding the refrigerator coming from the back panel of the freezer there was a condensation problem that should not occur at this part of the refridge . If you get condensation then the melt thaw effect happens causing water to fall into the refridge. I adjusted the cold and colder temp until this effect stopped. An other thing that didn't help to this problem is the door to the freezer not closing properly do to faulty seal on door or over loaded freezer. (cause condensation)
Hope this is help full.
Posted on Jun 01, 2009
  • pikeax Oct 25, 2010
    I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
The dripping of water resulted from condensation. Check your tepreature guage and make sure it is set according to user manual.
Posted on Sep 01, 2009
  • tehenry2003 Sep 08, 2009
    I recently noticed a problem with my frigidere refridgerator. After 5 years water is dripping inside the appliance. The tempreature remains cold and the freezer continues to work but the dripping of the water is very inconvenient.
    What could have gone wrong that is causing this water leakage?
My frigidaire refrigerator is leaking water outside the refrigerator. From the back of this fridge there is a drain pipe which runs down to the water tray. This pipe was pointing outside of the tray which make the water running down to the floor. I put the pipe inside the tray. After, it's working fine!
Posted on Jul 21, 2009
Do not our chase frigidaire
Posted on Mar 30, 2012
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Frigidaire galaxy
Thank you for your post, friend!
Based off the information you have provided your Frigidaire refrigerator is leaking water inside the fresh food compartment. If you could provide me your model number I would be able to provide more information. You can normally locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Water leaking from the water filter inside top right of fridge when getting water on side by side fridgidaire gallery series. How do I correct?
If the filter itself is leaking then you will need to replace the filter, otherwise check the o-rings and lines going to the filter.
Sep 25, 2011 | Frigidaire GLHS38EES Stainless Steel Side...
Leaking water inside filling up crisper drawer with water
Please check this link bellow to troubleshoot your problem when the unit is not leaking:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Thebottomfrontoftherefrigeratororfreezerdoor
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Aug 21, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
29,376 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
