Question about Lexmark X3470 All-In-One InkJet Printer
Cover Open Changed the ink cartridge and now the I cannot print, states cover open. Help, I have turned off and on,etc.
  • kayleebug May 28, 2008
    can not get to print, says cover open when it is not, tried unplugging all cords and still says the same.
  • Laura64093 Jun 07, 2008
    I changed out the ink cartridge and closed the cover but the error message: Cover Open shows on the screen and I can't do anything. Tried unplugging, turning off and on, turning upside down and shaking....still the same message. Any ideas????
    Genius:
  • 2,035 Answers
This is common problem with this printer if its within warranty please get it replaced or you need to change a small switch of the printer get it done in a local service center................
Posted on Jun 13, 2008
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
I have a Canon MP510 printer and have changed the print cartridges many times for refills but am now always getting error 6502. I've tried turning it on and off, unplugging it, holding down power button...
hi,
you mentioned that you turn off and on these is on of the solution of your problem
but in your case it doesn't work
error 6502 arise when ink tanks not snapped properly
follow the steps below
  1. Confirm that the printer is powered on and pull open the paper output tray .
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place.
note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
5.Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
1 -tank installed properly
2-not installed properly
6. check the status of each ink tank according to the way its lamp flashes.
  • - On: The printer is ready to print.
  • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • - Off: An error has occurred and the printer is not ready to print.
  1. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
  2. regards,
  3. cseian
Dec 16, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I changed both ink cartridges before my A940 printer was warmed up. I tried to print an alignment page and then a message came up on my screen that a cartridge was missing. I reset the color cartridge and ...
Open the top and left and right cover of printer.
There is lock system for open cover just pull the cover after removing screws.
Then You can see printer assembely inside it.
For open ink cartridges turn on the printer then ink cartridges are in middle then just pull ink cart to your direction then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 16, 2010 | Dell 948 All-In-One InkJet Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Oct 16, 2009 | Canon PIXMA iP1600 Printer
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
