Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
MFD2560HES Service Manual
The freezer works fine. The refrigerator is completely dead, but the light works. What is this?
  • 3 more comments
  • qtcourts May 26, 2008
    Freezer is completely fine, fridge is warm and light still works. Help!?
  • chiphelp Jun 03, 2008
    Exact same. Freezer still going strong, but fridge is not cooling & light is working. The ice dipenser doesn't freeze the water for ice either. PLEASE HELP!
  • Mdickmann Jun 03, 2008
    We are having the same problem, the freezer works fine but the refrigerator is warm but the light works.
  • AnyoneCanFix Jun 07, 2008
    There is a solution to at www.AnyoneCanFixIt.com. See the household section. It will save you charges of a refrigerator repairman service call.
  • Anonymous Jul 19, 2008
    freezer is cold works ok refrigerator doesn't work at all - light comes on.
  • 3 Answers
Could be three thingd that cause this
1) freezer is frozen block of ice solution unplug and thaw
2)fan motor is burnt out replace one screw inside top right side of freezer remove snap out cover sop out styrofoam and self epxlanitory from there
3) defrost timer is worn out aand might need replacement if first two items don't solve problem
Posted on Oct 02, 2009
    Problem Solver:
  • 9 Answers
Repair instructions are available at www.AnyoneCanFixIt.com for this problem.
Posted on Jul 05, 2008
My fridge is working but freezer is not?
i had to unplug mine for almost two days and let it completely defrost. it happened again within a couple of days. I read on website needed to let defrost and clean out area between freezer and fridge. the top of fridge was a little difficult at first but finally got loose cleaned all out and works fine now! it was all frozen up. Hope this was helpful and works for you also! good luck
Jun 13, 2012 | Maytag MFD2560HES Bottom Freezer French...
Freezer apparently wont defrost because it has that dry ice look. freezing fine
some times our equipment need rest !!! remove your food , unplug for at least two days, clean inside.after two days plug back
Mar 12, 2012 | Maytag MFD2560HES Bottom Freezer French...
How do you remove the damper cover located at the back of the top shelf??
How to begins on page 31 of the service manual Click Here=> MFD2560HES If you need more assistance than that let me know. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 21, 2010 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator is not cooling but the lower freezer is working fine what do I do? mfd2560hes is the model number
Might be an air restriction or a bad fan from below or even a door switch. I have a similar manual you might want to look through to git an idear HERE
Mar 01, 2010 | Refrigerators
My freezer works fine but the refrigerator does not
check to see if your fan in frezzer is working if not u need fan if it. is see if there is frost on back wall of frezzer if there is u have a defrost problem .u can unplug and let thaw with draw open for 4 or 5 hrs will work fine till u get service ther if it is defrost
Mar 18, 2009 | Maytag MFD2560HES Bottom Freezer French...
Freezer still works refrigerator not getting cold
These are notorious for having the evaporator fan motor go bad. See www.AnyoneCanFixIt.com for the way to repair it with detailed step by step pictues...easy fix. Takes about 30 minutes or less.
May 21, 2008 | Maytag MFD2560HES Bottom Freezer French...
defrost is your problem (heater, terminator, or defrost control)
Nov 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
890 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
