My monitor goes green , and when i hit it at the back it again comes to its normal color how to make it plzzzzzzzzzz help meee
  • 33 Answers
That is cold solder problem only, sometimes in a long time run the monitors has encountered intermittent or loose that is common. The solutions for that check the vga cable, open the monitor & look the color or chroma section for loose & dried joint pins, resolder it or resolder entire chroma for sure.
Posted on Sep 30, 2010
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Loss of one color in monitor
some of the vga conncetror pin is not working then that type of problem is presnet my sugestion is change the vga cable and install new one .....ok
Sep 22, 2009 | Computers & Internet
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
