Question about Miele Touchtronic W1213 Front Load Washer
Miele 2104 Washing Machine
Rinse Indicator Light Flashing then it empties
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
Posted on Mar 14, 2009
Why does Miele indicator stick on 'rinses'?
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
Mar 24, 2016 | Miele Washing Machines
Rinse light flashing
There are two main causes for this failure:
- carbon brushes are worn
- electronic is defective
The exact solution is depending on the model of your Miele washing machine and works for all modules that start with:
EDRU, EDSU, EDSTU, EL, ELP, EDPL,
you may visit youfixit.eu for a solution.
Miele repair Address and payment information
Feb 09, 2014 | Miele Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Touchtronic W1213 Front Load Washer Logo
293 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
