Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
The basket gets off center. So when it fills, the water spills out the back of the washer. What can I do to get it centered again?
  • Kenmore Master
  • 17,130 Answers
The water level pressuresensor is faulty and so the washer fills up beyond the limit.Due to the overload the washer gets out of control.So set the water level to the lowest level to see if its cut off.If not replace.
Posted on Sep 29, 2010
Maytag Bravos kicks out ol code even when washer is empty.
the basket is stuck on the center shaft causing overload condition try pulling up on basket as washer is filling if not may need new basket and/or transmision
Oct 07, 2015 | Maytag Washing Machines
After every wash I have to center the basket or it will cause leaking while filling up with water for the next wash. Why won't the basket stay centered. This has never happened before. Thanks
Hum sounds like a bad thrust washer on the agitator spindle but that should not effect water overflow? may be wrong and it could be a bad water pressure switch, if it does not detect water level it can allow an overfill? check with a multi meter for continuity. if u mean the basket is leaning in 1 direction to low then u may have bad balance counter weights or the metal has corroded and the drum cannot be held firmly when under pressure.
Sep 23, 2014 | Crosley Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Our Crosley washing machine (Model # CW5000W) will not spin all the water out of the clothes and is making a bad noise while it spins.
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
May 04, 2011 | Crosley Washing Machines
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
I have the inner basket out of a Whirlpool LSR5132PQ Top Load Washerand I filled it with water to see water dripping out around the rubber gasket? in the center of the outer plastic liner basket. I'm...
wow ok you have there srprnigs to remove on the right side remove the clip spring by removing the 1/4 in nut driver head screw,,and do the same for the lef side,,,noe you have 1 more spring in the rear,,the counter balance spring this has 2 screws remove them,,now on the right side remove your pressure switch hose...go to the bottom of tub and remove your tub to pump hose..ok nw left hold tub up and twist back and forth and pull at the same time...reverse to put together..onthejob
Feb 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
