Question about Canon Office Equipment & Supplies
Why is the yellow ink is not coming through on my canon inkjet mp780 - despite having cleaned, deep cleaned and re aligned the nozzles several times?
  • Canon Master
  • 17,129 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Sep 29, 2010
My printer will not print anything on the paper when I press print or copy. However, it is going through the motions as though it is but the paper remains blank. I have replaced the ink cartidges &...
You are doing well, keep trying the ink as it is a new cartridge has to still come through.
Do a few more deep cleans and then print some test pages. You may need to do this a few times.
Thanks michellelwol
Take care!
damnor01
Apr 16, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Pink and blue streaks on right side of page
most probably your "soak" pad need exchange. check your manual and change it. when you "deep clean" heaps of ink is absorbed into the pad exacerbating the problem, not solving it.
remove cartridges first and check them for existence of any foreign matter,
check for presence of debris under the head and parking place, remove if any,
i would suggest cleaning of printheads, albeit this can be risky (check first if your ink is soluble in water, isopropyl alcohol or methylated spirit, use that which solve your ink without clumping as cleaning agent), remove cartridges and allow appriopriate solvent to sit few second on metal rasters, wipe them with clean absorbing tissue and repeat procedure till solvent is "sinking" through the net.
remove old and install new absorbent pad under the print heads,
re-install inks, print rest page and then "normal" page. ink on first test page maybe very weak as solvent need to go through first.
if you follow the steps correctly, your should have clean print on the end.
"deep cleaning" is just waste of time, effort and ink. it is better if you create yourself a document with alternative lines of all three basic colours and black and then print it.
Jul 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Not printing yellow or blue despite full cartridges & clean head?
alcohol burnout print nozzles, you have ruined your printer head. you need to replace-it.
Feb 13, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
White stripes or bands running across the printout. I raelise that these are caused by some of ther print nozzles being blocked and have carried out the following: several clean head runs followed by...
have you done a print alignment.. You could also stand to take out the ink and clean the ink compartment with some q-tips and rubbing alcohol.
I hope this helps..
Nov 05, 2009 | Canon i350 InkJet Printer
Color copy not accurate from pixma mp780 it comes out yellowish
I would try using a set of OEM cartridges. Make sure to run deep nozzle cleaning and alignment.
Some aftermarket cartridges are not as well quality controlled and tend to be inconsistent and gum up the nozzles.
If you need a source for good aftermarket cartridges try LD Products online.
May 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mp780 printer will not print colors
I just bit the bullet and went out and bought Canon ink and replaced all my other Print Pal ink cartriges and my printer works like a charm again.
May 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Some colours not printing
I bet you are using non genuine ink, the MP780 will not put up with that ink, you will need a new printhead and maybe a purge unit. Take the machine to your ink supplier and get him to fix it as he supplied the ink
Jan 29, 2007 | Canon PIXMA MP780 All-In-One InkJet...
26 people viewed this question
old marine
old marine
