What is the solution when a system displays primary disk not found i replace yet the same
  • 17,130 Answers
Possible there are errors in the program files and you can try to restore your system to an earlier date.Select control panel--back up /restore,find the last restore point to be selected.If this wont help you will need to re install.
Posted on Sep 29, 2010
    Problem Solver:
  • 10 Answers
If you have replaced the HDD check or replace the SATA or IDE cable if all else fails update BIOS software from the OEM support site.
My HP Pavilion Entertainment PC won't boot up but displays error code 1720 - S.M.A.R.T. Hard Drive detects imminent failure.
Replace the hdd, install your OS and copy off your date. Reinstall your programmes to recover your backups.
Nov 07, 2016 | HP Computers & Internet
Operating system not found
do you have dual hard disk? check if your hard disk where OS installed is the boot drive/primary drive. press f2 during boot sequence then choose the proper hard disk
Dec 02, 2013 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
What causes the machine to display messages like primary hard disk drive 0 not found. primary hard disk drive 1 not found. strike the f1 key to continue, f2 to run the setup utility?
The system cannot find your hard drive. Remove the Power Cord, Open the Case, then remove the cables that are plugged into the hard drive and plug them back up. Reboot and see if it recognizes the drive.
If not, you can try the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 30, 2012 | Computers & Internet
Boot device not found please install an operating system on your hard disk Hard Disk - (3FO) F2 System Diagnostics For more information, please viit: www.hp.com\go\techcenter\startup
Hi
I think your by mistake you format Primary Driver, that way the problem will happen, please install the windows installation CD and make the primary drive with NTFS, and install the windows,
Good Luck
May 20, 2011 | Computers & Internet
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
