Question about Whirlpool Washing Machines
We have a Whirlpool 7 KG fully Automatic washing and the display is showing FE and the water is not filling in the Machine
    President:
  • 2,468 Answers
Either your water supply is shut off or the water fill solenoid valve isnt working to let water past the fill valve or the solenoids are not getting power from the control unit to do so
Posted on Sep 29, 2010
What does LF stand for on a Whirlpool Washing Machine?
LONG FILL....I usually means the faucets are not turned on fully OR you have a pinch in the hose and it is taking too long to fill (LONG FILL).
Jun 02, 2015 | Whirlpool Washing Machines
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Nov 19, 2014 | Whirlpool Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
I have a fully automatic whirlpool washing machine H-65 model. Rcently, it is sterted displaying the error code-"dE" after finishing bthe wash cycle. That is, the machine does washing and drains the dirty...
Hello Ajithkumar,
"H-65" is not resolving as a MEANINGFUL
MODEL NUMBER...
Most Frequent Causes for dE - DOOR OPEN ERROR // Main control detecting a problem with door/lid lock system...
>> In the MIDDLE of a cycle...
I would first have to ask if you are IGNORING
the very VITAL INSTRUCTIONS to use only
"HE" (high efficiency) washing detergents...
IGNORING this very IMPORTANT instruction is
PURE NEGLEGENCE and can damage the machine.
I would suggest if you don't want to buy a replacement
machine... you treat this one according to the OPERATING
MANUAL.
Carnac the Magnificent
Aug 26, 2017 | Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
I hear some different noice along with slight vibration, when water filling in the washing machine. my washing machine model is Whirlpool F65 fully automatic one 2 one 2 wash. Its need any service?
Could the sound be described as a chatter / rapid clicking?
If so, it's probably the inlet valve for either the hot or cold water which is not opening all the way due to a dirty/malfunctioning solenoid valve.
Charlie
Aug 14, 2009 | Whirlpool Washing Machines
Washing Machines Logo
274 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
