Question about Akai PT4298HD Rear Projection Television
My AKAI 54in Projection tv-5598hd is 7yrs. old, has never had any kind of service. The picture is not sharp anymore. What can I do to make it better?
  • Akai Master
  • 5,138 Answers
You need to Clean the Mirror and Top of Tube lenses of Dust and dirt.
Posted on Sep 29, 2010
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
Fuzzy picture on tv 54in
Check your coaxial cable connection and inspect it wiggle it while the set is on if the problem clears replace the cable. Check to see if the male connector that sticks out the back of the set isint loose to the point where it moves when you touch it. If it does you need to have it looked at by a tech usually this problem can be solved with a little soldering but could get more complicated. Depending on the age of the set the fluid in the CRT's gets old and cloudy and light cant shine through it makeing your picture appear fuzzy. Your local tech should be able to change the oil in your set. Finally you could have some bad filter caps but I doubt it.
Jun 12, 2010 | Akai PTH5498 54" Rear Projection...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
Do the AKAI PTH 5498 TV's have replaceable lamps like you hear so much about for other rear projection TV's? And if so, any suggetions on where to find the lamps? I am hoping this can improve the sharpness...
No your model has three CRTs (picture Tubes) cleaning the mirror may help to restore the sharpness and brightness unless you have other issues. I would try cleaning the mirror first. Dont use windex, just a soft damp cloth with water then dry
Dec 20, 2009 | Akai PTH5498 54" Rear Projection...
Colors (tube tv) periodically become bright and flicker
this sounds like one of the tubes is shorting out ,or have you or do you know if your tv tubes have been serviced and the fluid checked in them reciently.i know sone tv proj carries some kind of solution in the tubes to keep them running cool ,call a service rep or the panasonic co and ask them tech support
Apr 16, 2009 | Televison & Video
Change CRT coolant in AKAI Pt5598HD
The CRTs in modern TVs do not hold a charge because the HV circuit shunts it to ground whenever you power down the TV. You can clean the lens of the CRTs but you can't change the coolant or should you even try. You'll notice that its sealed from the factory. If you suspect a problem with the coolant or that it has dried up or leaked out, you must replace that CRT.
michtech
Feb 20, 2009 | Akai PT5598HD 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
AKAI 1080i HDTV 42"
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Burning smell and distorted picture
One of the components in the horizonatl deflection circuit went bad like a capacitor,the price will depend on the actual part that went bad and your location,the service call in NY could be 300.00 but in pittsburgh might only be 150.00.I still belive is wort repairing.
Oct 18, 2006 | Akai PT4799HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
55 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
