Question about Refrigerators
Fridge has stopped running, there is a red-orange glow in the back of the freezer compartment
    President:
  • 2,468 Answers
Its just defrosting,that will go out after the defrost cycle and it should recool after that
Posted on Sep 29, 2010
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Orange glow in freezer, what is it?
Your refrigerator is a frost free unit. The derost cycle in a refrigerator is controlled by a timer or an electronic control. When a unit goes into defrost, the fans and compressor are turned off and a heater in the freezer is energized. This is the glow that you see, and the hissing sound is the water droplets, from the melting frost, making contact with the heater. This is perfectly normal.
Apr 27, 2009 | Refrigerators
Not Freezing/Cooling - A Red Glow...
  • the defrost timer and bimetal thermostat have apparently both malfunctioned. (rare)
  • if someone has worked on it in the past they may have bypassed the  bimetal thermostat.
  •  the bimetal thermostat turns off the heater if it gets too hot (above 45 in the freezer)
  • and the defrost timer is only supposed to stay in defrost for 8 minutes or so.
  • so considering the heater was on and it was hot in the freezer is evidence of these two components not doing their job.
Jul 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frosty
IS THE BACK OF THE FREEZER CLEAR ICE OR WHITE FROST?
IF IT IS WHITE FROST, THERE IS A FAILURE OF THE DEFROST CYCLE. THREE COMPONENTS NEED TO BE CHECKED. THERE IS A DEFROST TIMER, HEATER AND BI-METAL. THE HEATER AND BI-METAL ARE LOCATED BEHIND THE BACK WALL OF THE FREEZER WHERE THE FROST IS BUILDING UP. IF IT IS A WHIRLPOOL, THE TIMER IS LOCATED IN THE FRESH FOOD COMPARTMENT WITH THE COLD CONTROL. LOOK FOR A HOLE THE SIZE OF A DIME IN THE CONTROL HOUSING. THERE IS A SMALL DIAL IN THERE THAT CAN BE ADVANCED WITH A SCREWDRIVER.
ADVANCE IT UNTIL YOU HEAR A STRONG CLICK AND THE
REFRIGERATOR SHUTS OFF. THAT WILL BE IN THE DEFROST CYCLE. WAIT ABOUT TEN MINUTES AND LISTEN FOR SIZZLING IN THE FREEZER COMPARTMENT. ALSO LOOK FOR A RED/ORANGE GLOW IN THE FREEZER. IF THAT HAPPENS, THE HEATER AND BI-METAL ARE O.K.
REPLACE THE TIMER. IF NOT, TAKE THE BACK PANEL OFF THE FREEZER AND CHECK THE HEATER AND BI-METAL WITH A VOLT-OHM METER. REPLACE THE DEFECTIVE PART.
ON G.E. REFRIGERATORS, SOME HAVE THE TIMER LOCATED BEHIND THE TOE PLATE AT THE BOTTOM OF THE REFRIGERATOR. ON OTHER REFRIGERATORS, IT IS LOCATED INSIDE THE COMPRESSOR COMPARTMENT TUCKED BACK IN A CORNER.
Mar 31, 2008 | Refrigerators
Refridge
the condensor fan motor is bad!! Pretty soon the compressor will be too! Take the back cover off and put a fan blowing on the compressor this will help until the fan is replaced!!! Please!!! A solved rating for this one!! Its dead on
Oct 04, 2007 | GE Americana A3316ABS Top Freezer...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
