Question about Peavey Pv 2600 Power Amplifier
My 2 pv 2600 amps have the same problem.all toroidal transforsmers busted.no smell or signs of over heating or over used.i found a cut or open wire on the windings.what causes the cut or open to the windings?
  • Peavey Master
  • 5,603 Answers
Mis-handling is the usual cause of this. This can also occur if the clamps don't hold and the transformer slides around. OFTEN you can splice in a short piece of magnet wire to repair these. Splice and insulate well.
Posted on Sep 29, 2010
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
Cut out on one occassion & how often does amp need service
Hopefully not often. They are very complicated in design. Keep ALL airflow paths clean and if in a cabinet, give adequate air movement... use a fan if necessary to vent the cabinet. The unit has a string of diodes to adjust the quiescent current in the power amp and if you overheat the unit it will try to protect itself by shutting down.
Jul 25, 2011 | Peavey Pv 2600 Power Amplifier
One chanel of my pv 2600 amp is playing very low
Clean all back switches first of all, use a cleaning solution spray and give a 3 shot per switch, then push in-n-out several times each one and check amp functionality again.
May 29, 2011 | Peavey Pv 2600 Power Amplifier
As a starting point clean ALL switches on the back of your amp, including the Stereo/Bridge switch then re-check functionality, good luck.
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
Do you know what regulator/ rectifiers are used and their numerical values so i can repair my fried pv 2600 these are the row along heat sink small black ones 2 pin and 3 pin cheers
7815 and 7915 plus and minus regulators specifically. Diodes fr the 15 supplies are 1N4001 but you can use 1N4007 or anything in between.
Big power rectifiers are 2504's... which are probably 25 amp 400 volt modules.
Jul 18, 2010 | Peavey Pv 2600 Power Amplifier
How can i prevent it from over heating
Do NOT block airflow via the vents and fans. If other equipment blocks or restricts airflow, space out the items in the rack.
Some amps have vent fins at the sides and these must have free airflow.
Do not go below the load resistance rating by paralleling too many speakers.
Do NOT drive the amp into the clipping region with too high volume.
Jul 16, 2010 | Peavey Pv 2600 Power Amplifier
Amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
141 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
