Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Projection TV No Picture No Sound
I have a Mitsubishi VS5051 projection tv. While watching tv it just went black with no picture or sound. I thought the house fuse blew but it did not. I clicks when you turn it on, and I can hear static from the speakers when I move it. I was able to find and check four fuses and they are fine. There are supposed to be a few more, but of a different type and I could not locate them, I'm thinking they do not look like the others. I am hoping for an easy fix or an estimate of what the repairs might be.
Hi Chelon alot of Mitsubishi tv's around the time the model number you are stating where built have a small PCB on the yoke of the picture tubes, connections on these boards (one of them) break down so the set loses one of the scaning circuits (vertical or horiz) the circuitry senses this failure and shuts off the picture (some models the whole set) this is to protect the picture tubes, try wigglin the heavy cable going to each of the 3 tubes (unpluged from wall socket) then plug it in and turn it on. Once the set is up, carfully wiggle each of the cables goin to the yokes until the screen flickers or flashes now you know which one is bad repair it is a bit of task but lets see it you get this far first.
Posted on Sep 20, 2008
Picture but no volume
I went to menu then press net command and press audio then enter. Then I press the arrow up on the adjust key and switch it from AVR to TV/Video.
Jan 06, 2010 | Mitsubishi WD-65731 65" HDTV
Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Nov 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Lost picture
sounds like video card failure mode, 101..you a technically adroit person?
Apr 03, 2008 | Televison & Video
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Picture blank; sound on
Do the self diagnosis test first, search threads here or goto www.ctechnicians.com and read
Dec 03, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
