Question about Fuji FinePix F810 Digital Camera
My Fuji FinePix F810 Digital Camera will not charge.....why does the red light go out?
  • 198 Answers
SOURCE: can't download pictures from camera
perhaps your Fuji download program is corrupted, or your cable has been broken. Most computers now have a direct plug-in for your memory card, as well as plenty of built-in programs to download your pictures. I like the Vista Photo Gallery (come to think of it, it is the ONLY thing I like about Vista. At any rate, unplug your xD chip from the battery compartment (you can just pull it out, or push it and it pops up), (and close the battery compartment, or you will have to reset the date and time), plug it into your computer, and wait for a bunch of programs to pop up eager to download your photos. If that doesn't work, you may have a bad chip--but if you had a bad chip, you couldn't view your pictures on your camera. If you have XP, you should be able to see the xD as a new drive if you plug it in--not sure which programs will pop up, but you may be able to move the pix just like any files from one drive to another. Good luck. Incidentally, if you need a new cable, internet charges range from 3 to $25.
Posted on Jan 21, 2008
robmcd27
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
  • 24 Answers
SOURCE: Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Posted on Sep 11, 2009
SOURCE: Fuji FinePix F810: flash light does
Hi guys,
I've had the same problem with my f810. I found the solution on a german photography forum:
while pressing the flashbutton with your thumb on the rearside of your camera, push on the body of the camera under the flash on the frontside with your index. try various positions of your index and you'll see: it will open!
neto
Posted on Oct 29, 2009
SAFFOTO
  • 77 Answers
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Posted on Jan 29, 2010
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
Fuji finepix f810 flash wont pop up when button pressed
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
May 22, 2011 | Fuji FinePix F810 Digital Camera
Cannot install my finepix f810 onto my computer, correctly.
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free program Picasa ( http://picasa.google.com ).
Feb 04, 2010 | Fuji FinePix F810 Digital Camera
Fuji FinePix F810: flash light does not pop up when button is pressed
Hi guys,
neto
Oct 26, 2008 | Fuji Cameras
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Black screen no image otherwise all works so cant take photos Fuji finepix F700
CCD failed, contact fuji, they got product recall for some camera models with faulty CCD.
Fujifilm Service Advisory:
Fujifilm camera - CCD sensor
If your Fujifilm FinePix digital camera serial number is on the list and experiences the symptoms described above and have no other additional damage/malfunction, Fuji Photo Film, Inc. will repair your camera at no charge, even if your standard one-year limited warranty has expired. If your Fujifilm digital camera is beyond the standard one year, limited warranty period, you will receive a written estimate for any additional damages or malfunctions not listed in this Service Advisory.
Finepix A303, F410 & F700 - Serial numbers
- FinePix A303 - 3JA4**** - 3JA5****
- FinePix F410 - 32A1**** - 32A6**** - 32A7**** - 32A9****
- FinePix F700 - 33A0**** - 34A1****
Fuji Photo Film - Camera faulty
If your camera got the symptoms please package the camera carefully using ample padded material to prevent damage in transit. Include your name, address and phone number with the shipment as well as a general description of the problem. Keep a record of the camera's serial number and shipment tracking number. Ship your camera to the Fuji Service Center.
Mar 12, 2008 | Fuji FinePix F700 Digital Camera
Finepix 50i charging problem
the Battery has past its best-replace it.
Dec 24, 2007 | Fuji FinePix 50i Digital Camera
Fuji FinePix F810 Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
