Question about Garmin GPS
Garmin GPS I am trying to use my GPS but canot see anything on the screen. I replaced the fuse in the power source and am now able to hear that it is on, but still a black screen. Can you help me figure out what is wrong?
  • 6 Answers
You could try the reset button... on the Nuvi it's located beneath the label on the side of the unit. Best way to activate is with a paper clip. (You will have to poke thru the label)
Posted on May 25, 2008
The screen on my garmin gps is dark/black but there is sound
Let the battery totally die, pressed the rest button and then charged the battery fully and then turned it on. The screen came on and it is working just fine now.
Jan 13, 2010 | Magellan Roadmate 1200 Car GPS Receiver
When plugged into the car power source my Garmin Nuvi 1350 screen turns black, but I can still hear the audio. When I unplug the power source the screen comes back.
HAVE YOU THE GARMIN POWER LEAD? IF NOT IT MAY BE THE FAULT, IF YOU HAVE THEN IT STILL MIGHT BE DEFECTIVE, TRY AND SOURCE A NEW LEAD OR CONNECT TO PC WITH MINI USB SEE IF THAT MAKE A DIFFERENCE, IF NOT THEN DEFECT IN UNIT, TRY SOFT WARE UPDATE FROM WWW.GARMIN.COM
Dec 15, 2009 | Garmin nuvi 1350 Car GPS Receiver
My garmin wont turn on iv tried charging in car, computer, changing fuse, it just wont turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold the lower right corner of the screen, while holding the lower right corner, switch the power to the on position. once you see the message "do you really want to delete your data" select yes, then follow the on screen instructions
bill
Nov 23, 2009 | Garmin nuvi 765T GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Display dims when connected to external power
mine had same problem. If I switched it off and then back on using the switch at left upper edge the screen would then come on at normal brightness. Mine later developed other problems (freezing up) and I have since returned it for replacement.
Mar 15, 2009 | Garmin nuvi 885T GPS Receiver
My Garmin c550 will not come on anymore. The screeen is black
Check the 12v power cord to make sure its still powering/charging the unit. Usually they have a light on them that will show if its receiving power or not. You can also unscrew the tip of those things (on most cables) and check the fuse to see if its blown. If its not lighting up and the fuse on the cable is ok check the one in your truck to see if it needs replacing.
If the cable is not the issue then the GPS is probably dead. If its not under warranty the flat rate repair fee from Garmin is $200
http://www8.garmin.com/support/outofwarranty.html
Jan 18, 2009 | Garmin StreetPilot c550 GPS Receiver
StreetPilot c340 will not come on even when plugged in
I had this problem before, i called garmin and they told me that the charger cradle was not design properly so it sometimes doesnt charge...anyways...carefully remove the grey cover around touchscreen and there is a master reset which will set it back to factory...it worked for me...good luck!
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C340 battery not charging
The Garmin batteries tend to die after about 2 years. Garmin will replace the battery for you but prepare to pay top dollar. It is a shame because the problem is commonplace. They should have made the replacement user friendly. The battery is buried deep inside and it is soldered.
May 06, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
