Question about Hoover HW160M Front Load Washer / Dryer
The macine dryer elements is not working, the cycle runs but does give out any heat.
  • 2,272 Answers
The dryer element not working.This elements are called heating element.If heating element is not working then it will not heat. The heating elements needs to be checked by meter.If the element is got cracked in between or if the element is got loose from its fittings.It has to be checked and replaced. To get the required parts for your washing machine,. You can get it from here.please click on the l,ink below:---- http://www.buyspares.co.uk/washer-dryer/hoover/hw160m/catalogue.pl?path=495970:496363,45786:495976&model_ref=65712&illustration_ref=0 -------------- Also to see ,how the element look.Please click on the link directly:--- http://shop.ukwhitegoods.co.uk/Washing+Machine+Parts/Candy/Heaters+%252526+Elements/91201546+Washing+Machine+Water+Heating+Element.html?osCsid=3fa1f6ae0c678806d7a7d34dd3255160 ----------
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Sep 29, 2010
Not heating up
if ur lucky pull macine out and look on back for a small button this will click when pushed. if though no button u dont give make model or anything to know.but element/s or thermistors all cheap but engineering costs make unviable if u cant diy
Jul 17, 2015 | Dryers
Dryer will run but it will not heat?
Heating cycle failure...
a) Heating element faulty.
b) One of the safety switches (Thermal fuse / High temp cut off etc) has burned out.
c) Rare case... Control board not giving power to heating circuit. Control board failure.
d) Heating sensor issues. Try the time dry to see there is heat instead of auto cycle. May be your heat sensing thermistors....
But mostly either above a) or b) reason.
Apr 24, 2015 | LG DLG9588 Dryer
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Samsung DV419AE Dryer
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not heat up
It could be the heating element, thermal fuse, or high temp thermostat. The timer won't advance at all on auto dry cycles, if the heater isn't working.
Get an Ohm-meter and find the component that measures infinite ohms.
Mar 10, 2008 | Dryers
Hoover HW160M Front Load Washer / Dryer Logo
82 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
