Gpx stereo hm1836 doesnt play cds
Hello i just bought a new gpx stero model hm1836 when i turn it on the motor grinds and the cd tray doesnt spin the open and close button doesnt respond whats wrng
  • 5 more comments
  • clee5 May 25, 2008
    can you fix it
  • shotzie1 Jun 01, 2008
    we bought a gpx hm1836. Radio and cassette works fine. cd will not respond when button pressed. does not turn, whats wrong and how can we get a replacement manuel ?
  • Anonymous Aug 03, 2008
    My GPX Stereo HM1836 does not play cd's. I cleaned the heads and the cd's that I wanted to play and it still won't play.
  • patteber Sep 30, 2008
    bought a gpx model 1836 and the cd door will not open and it will not play cd's.can you help me?
  • langers5 Jan 19, 2009
    i hav the same problem with a Sony mini compact stereo which i got to open my putting a business card in it an sliding that around the inisde of the cd drawer but then when i want it to close it closes then shortly just ejects itself again without playing
  • Sheila Jo Jan 25, 2009
    I have a GPX, stereo, it has 5 disc changer, am/fm radio, cassette and phonograpic player, all work except the CD player, the tray opens and closes, but does not play CDs. What is wrong here? My email address is sheila.wheeler@mchsi.com
  • Anonymous Jan 27, 2009
    Can not play cd's
techman
  • 3130 Answers
SOURCE: CD Player Tray Spins Continuously With or Without Disk
Yuo didnt mention if it was used or new,. If it was new I wouldnt mess with the unit and take it in under warranty, as there is no quicky fix for this one. Its going to turn out to be a problem with the disc motor servo circuit or the microprocessor. Good Luck
Posted on Aug 06, 2006
  • 275 Answers
SOURCE: CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Posted on Sep 20, 2006
SOURCE: Not Recognising a CD
I had the same problem with my C541 player, I solved it simply cleaning the lens area with cotton swabs. No other "no disc" fake messages so far... good luck! Luca - Rome (Italy)
Posted on Jan 28, 2007
  • 16 Answers
SOURCE: problem with stereo playing cds
I'd be interested to know the brand, but you could try this:
(Assuming your CD player has only a standby button, not a full On/off button). Unplug the CD player from the mains. Leave for 30 seconds. Connect to mains and press eject as early as possible. Hopefully, this will allow the system to eject the CD before it starts trying to spin it.
Ultimately though, if it plays but won't open, it's likely to be a cog / gear on the drawer that has failed rather than some software fault as the CD plays.
Repair may not really be economical - depends on brand / value etc. If the disc is more important than the player you might end up attacking it....
Posted on Jan 15, 2008
SOURCE: Stereo CD player/tuner XC-L11 not working at all
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Posted on Sep 29, 2008
Gpx stereo cd won't work
The laser pickup head has failed, or the pladder motor that spins the disc is open, or there is no voltage to the motor. Chances are the whole assembly will need to be replaced, but as a rule it is cheaper to replace the stereo.
Jun 23, 2012 | GPX HM3817DT Shelf System
Sony CMT-EP515 CD Shelf System. CDs wont play. Place CD in tray and close, disc doesnt spin but 4 distinct clicks heard then nothing
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
Aug 04, 2010 | Sony CMT-EP515 CD Shelf System
Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Mar 24, 2010 | GPX KCCD6316DT Shelf System
How do you turn off the demo feature? Or find a manual? I lost mine in a flood.
Hello
Jus post the make and model of the device you need the manual for.
With more details you can be helped very quikly.
Best regards
Andrea
Nov 05, 2009 | Aiwa Audio Players & Recorders
Disc Grinding, Not Motor or Magnet Thing
I think the only option for you is buy a replacement drive off ebay (you want the same model doesnt matter about the FW version) swap the PCB of the drives over so the new one has your old PCB. The same thing happened to me but when I lubed the spindle the grinding noise went away for a week at a time, so I got fed up of constantly lubing it and bought a new one off ebay and swapped the PCB worked brilliant ever since. Hope this helps.
Paul
Apr 25, 2009 | Microsoft Xbox 360 Console
2002 chevy monte carlo stero problems
The stereos antitheft isnt armed is it. This makes it so the stereo wont work until it is disarmed by typing in a 4 number code for your car. Its only supposed to arm if the power is cut though such as the fuse was pulled or the battery was disconnected from the car.
Feb 03, 2009 | 2002 Chevrolet Monte Carlo
GPX HM1836 Boombox CD Tray spins all the time and doesn't stop
Hi
Unfortunately, I'm not familiar with your model, but the way it is supposed to work, is when you load a CD, you will see the laser lense move up and down a few times as the laser attempts to focus on the disk, and as well you will see the spin motor spin a few times. If the spin motor is going all the time, and the driver chip has been changed, then there is either a circuit problem giving the "on" pin of the driver ic a signal to spin at all times, or the microprocessor that runs the Cd has failed and is sending signal to spin constantly. Unless this is a hugely expensive blaster, I would replace it given the type of problem you are having.
Good Luck!
Dec 17, 2008 | GPX HM1836 Boombox
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
147 people viewed this question
 Grubhead
Grubhead
