Question about Philips Magnavox 51MP392H Rear Projection Television
My Magnavox 25tsc60101 seems to have gone back to its store setting where it advertises itself and I cannot control it via the buttons how do I fix it?
  • christoph9711 Sep 30, 2010
    The users manual is not available, is there a standard method for resetting Magnavox TVs?
  • 666 Answers
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Posted on Sep 29, 2010
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
SDTV REMOTE CODES FOR MAGNAVOX
Hi
On the URC 4330 model the Magnavox brand is not listed in the code index.
Therefore, you should be aware that this remote may not have code stored in its pre-programmed library to allow it to operate Magnavox.
There is a code search function with this remote and this is your only other option in a situation such as this.
TO SEARCH FOR YOUR CODE FOR YOUR TV
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first so this may take some time to complete.
5.Once you find the point at which the remote operates the TV press and hold SET until the LED blinks twice, then release SET. This locks in the code.
As I say - the remote may or may not compatible with Magnavox. However this search function is there to use in situations such as this.
Hope this helps. Thanks for using FixYa.
Jan 09, 2010 | One For All URC-4330 Remote Control
How do i program my hamton bay universal remote to wor with my magnavox vcr/dvd recorder combo unit
Magnavox VCR codes are 007, 011, 028, 032, 059
Magnavox DVD code is listed as 001 only.
Manually turn on the device. Press and hold the SET button then press and release the VCR button, then release the SET button. Enter a three digit code then press power. If it does not turn off the device, try the next one.
You might also try the 'code search' if none of the above codes work. Press and hold SET then VCR and release both. Then Press and release the SET button again. The indicator light should begin blinking. Press and release the POWER button until your device turns off. You may have to go through up to 200 different codes until it turns off. Once the device does turn off, press the VCR button again to store the code.
Jun 19, 2009 | Universal Remote Control Hampton Bay...
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
