Question about JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black
JBL On Stage for iPod
It won't connect to either iPod, I have to plug the iPod into the base of the On Stage and sort of force it down and forward to get any sound. If I let go even one millimeter...no connection and no sound. The iPods are fine with all my other systems.
  • 2 more comments
  • xtravoice Jan 11, 2009
    Suddenly none of my iPods will connect with my speakers. I wiggle them and hear a little static and sometimes a burst of sound. Obviously something is up with the connection, which I've tried to clean to no success.
  • persefoni_pt Feb 01, 2009
    only noise but no sound when i connect my ipod device
  • susond Feb 09, 2009
    Have same problem. If I hold the ipod and tilt it forward I get sound. If I just let it go and sit on dock, it tilts backward and I don't get any sound.
    I put a wedge of paper behind the ipod to hold it in place and that worked but why is it happening?
  • Anonymous Mar 13, 2014
    jbl stage ipod dock remote not working
Hi, I guess that's just a problem that can't be solved by yourself, you'll probably have to bring it back.
I have thesame speakerset, but I don't know how you can remove that thing where the ipod stands in. That plastic thing that comes in a lot of different sizes. I hope that you can help me with removing it and putting an other one in.
Posted on Dec 15, 2008
Nano not compatible with On Stage
It will actually work, however, you will not be able to dock the iPod® Nano into the JBL On Stage™. You can connect the audio in cable to the headphone jack of your iPod. That's the only way, hope this helps. Pls rate solution. Thanks!!
Jun 12, 2008 | JBL On Stage Micro Speaker Dock for Apple...
How to connect pendrive usb to JBL ipod dock
Buy a universal USB cord which has many different connecting ends. Easily available in electronic shops.
Connect USB 2.0 to the pendrive and the other end to JBL IPOD dock
Nov 23, 2009 | JBL On Stage Micro Portable Speaker Dock...
No Sound from JBL On-Stage 400
The power supply consists of two parts: the AC cord with a two-prong connector on one end and a double barrel plastic connector; and the large rectangular power supply which has a dual prong receptor on the side and a long cable which plugs into the JBL unit.
In my case, I had plugged the double barrel plastic connector into the dual prong receptor backwards. Even though I was getting full power to the unit, this somehow caused the speakers to become inoperative.
Of course, I would offer a recommendation to JBL that their power supplies are made to be "dummy proof" so this does not happen to others as well.
Jul 29, 2009 | JBL On Stage Micro Portable Speaker Dock...
My jbl radial, when using a 120 gig ipod, will skip songs.
Not a solution but mine sometimes causes my ipod to skip mid-song to the next song or podcast as well. JBL customer service is usually good and I've been meaning to check with them since I finally figured out it's the radial and not my ipod.
Jun 21, 2009 | JBL Radial Speaker Dock Docking Station...
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
I want my ipod to charged without my computer
What you need is the wallwart that (Sometimes) comes with the iPod. that way you can charge it without connecting to the computer, Check the iPod shop for one or there are some generic ones available on google shopping.
Dec 30, 2008 | JBL On Stage II with Remote Remote Control...
Compatability with 4th gen nano
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Sep 26, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Logo
327 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
