Question about Canon PowerShot SD1100 IS Digital Camera
I want to erase 800 + pictures from my memory card. there is a way to do it but I do not know how.
    Brigadier General:
  • 11,967 Answers
Assuming you have safely downloaded them to your computer, go into the camera menu and find "format"...follow the on-screen instructions to erase the card.
Posted on Sep 29, 2010
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
How do I format a memory card without erasing pictures already on it?
No, format will erase all data. Try doing chkdsk <drive letter> /f in the command prompt.
Dec 22, 2012 | SanDisk 4GB Secure Digital High Capacity...
I don't know how to transfer pictures from my camera to my memory card
With no card in the camera, go into the menu and find "format". Follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
Nov 10, 2011 | Olympus FE-370 Digital Camera
I used to be able to take 1000+ pictures on external memory card. Now I'm trying to take pictures and it will only allow me to take 9 pictures but on the camera memory. I have reset the camera to factory...
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the format thing again (This will erase your card so if there are pictures on it, download them first using a separate card reader).
Jul 02, 2010 | Olympus SP-565 UZ Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Lost pictures?
I'm sorry to say that the card is erased. A format is a complete erase of the memory card.
However, your pictures aren't necessarily lost. First of all, make sure you don't use the memory card in the camera. As long as you haven't taken any new pictures on the card, you should be able to recover your pictures.
Next, you will need a USB memory card reader that accepts your type of memory card.
Connect the card reader to the PC, then insert the memory card in the memory card reader. Then download this program: http://www.datarescue.com/photorescue/download.htm
This is a program for recovering lost pictures from formatted memory cards. It's a free trial version, that will show you the photos that can be recovered. To do the actual recovery, you will have to buy the program for $29.
I hope this helps you! Let me know if I can provide more help.
Regards,
/Chris
Jan 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
I just got back from my first cruise and took so many pictures. I don't have a USB so I went to go place the memory card into my computer but it won't read the card. So when I put the memory card back into...
i know its not ideal but why dont you borrow a friends camera and usb lead, put your card into their camera and upload them onto your computer via their camera, at least then you can save your special pictures and rectify the problem later
Jan 18, 2009 | Cameras
Things i dont know in using motorola v3i
for erasing messages you should click the button that is in the middle, at the top of all buttons of the phone.. then you will see the options you can select, between them, there is "erase", you can choose to erase them all, or just the message you were reading..
don't know is themes can be dowloaded.
for the pictures it is quite the same, if you go to options, using the same button, then you can choose something like "use different memory device" and if you choose that, you can choose between the intern memory of the phone and the memory card you are using..
I hope this was a bit helpful.. Can you rate this solution please??
Dec 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Erasing pictures
If you erase them off your memory card they shouldn't be transfering back onto your computer. I would say that maybe they are saved on your internal memory of the camera also. Take your memory card out and see if when you turn the camera on you have pics in the camera stored. If you do delete them then. :)
Jan 04, 2008 | Casio Exilim EX-V7 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Canon PowerShot SD1100 IS Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
