Re: What is the right file for n 73 rm 133 tell me
It varies according to the product code , anyway let me give you one link.You can try with the latest i.e. the highest version.Blue-Nokia.com by Obnoxy. Thanks Good luck
0042 0076 0094 0601 0616 0654
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
1) Check your version on your phone by pressing *#0000# You will see your current softwareversion (currently probably 10.something and that's why you are on this page). The model probably is N97 and the type RM-507.
It is also important you have already installed the PC suite.
2) download the new firmware via Navifirm
Run it (start-up takes a while, it retrieves data from the internet) and select the version that you want to download. Make sure that you know which firmware you want to download. A list of all the product codes (and the ones which are already updated can be obtained here)
3) Store the files that you have downloaded in following folder: C:\Program Files\Nokia\Phoenix\Products\RM-507
where RM-507 is equal to the code that you retrieved in step 1
You now have possession of the part that you need to upload to your phone!
To be able to flash this on your phone you need toinstall and get J(ust) A(nother) F(lasher) working
Download JAF version 1.92.62 here, and in order to get it working download OMG JAF PKEY Emulator v5: here
version 1.92.62 does not know the N97, so 1.92.64 can be downloaded. You don't need the .exe file just the .ini files. So download JAF version 1.92.64 here and only put the .ini files in the directory where you installed version 1.92.62
When this is done, open OMG *** PKEY Emulator v5. After pressing go without changing any setting you should get JAF running.
You first get an error message that Box drivers are not installed. This is OK as you don't have a box. If you get a query regarding installing new drivers keep the ones you currently have (those you got when installing the OVI suite and they are perfect)
Press BB5, now we need to tell the programm where to get the new flash files.
First select: dead USB (even if your phone is still working) Manual flash , factory set and normal mode.
If your phone is still working you can press .ini when it's connected. It will automatically know where your You can do this by connecting your phone and press: use ini, or when it's dead press the buttons MCU , PPM,CNT and APE one by one.
You should point them to your directory
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.core.C00 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.rofs2.V28 (SWAP the file from RM-505_11.0.021_prd.rofs2.V26 and rename it to RM-507_11.2.021_prd.rofs2.V28) CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM505_507_11.0.021_uda9_001.uda.fpsx
Also make sure you click the option: Change also product code and uncheck CRT 308. Now make sure your phone is switched off and battery is in! Now take out the part that goes into your phone untill the program tells you to switch on your phone after you pressed FLASH.
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
