Question about OKI B6500 Led Printer
OKI B6500 service error 03 - OKI B6500 Led Printer
Hola buenos días tengo una impresora oki B6500 se le cambio el tonner despues del cambio manda el mensaje de tonner bajo que debo de hacer para quiatar el error que marca
Posted on Jan 11, 2011
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: oki b6500 new printer has
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Posted on Jun 15, 2011
  • 3 Answers
SOURCE: service error 02
SE 02
: Software Exception
Posted on Sep 22, 2010
How fix oki B6500 loading display error
gravity reset. seriously, hold it about 9" off the floor and drop it evenly. repeat if not fixed. this was in an oki tech bulletin. there is a ribbon cable deep inside that comes unseated. unless you want to take the ENTIRE printer apart perform the steps above. :)
Aug 19, 2014 | OKI Office Equipment & Supplies
Oki b6500 is stuck on initializing
the main board needs to be replaced
Apr 21, 2014 | OKI B6500 Led Printer
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
Oki b6500 new printer has error code 03
Jun 15, 2011 | OKI B6500 Led Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
OKI B6500 has ID mismatch error....need to know how to fix. Thank you
Basically the machine does not recognise the image drum. You maybe using the Xerox equivalent which of course wont work. Replace the drum with an OKI one and it should work even though its really a Xerox printer.
Jul 13, 2010 | OKI B6500 Led Printer
Service error 02
SE 02
Jan 12, 2010 | OKI B6500 Led Printer
OKI B6500 Led Printer Logo
5,633 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
