Question about Polaroid FLM-2601 Television
Toshiba 50hp82 plasma
Power turns off and on tree or four times for about 2 seconds each time.
I took it apart and checked fuses, Inspected CAPs and didn't see any blown ones. I'm currently going through and checking for cold solder joints and touching up any questionable ones. If you know of any common problems with this model or can assist in any way I would greatly appreciate it I got the thing cheap and am hoping I can fix it and use it as a monitor for my computer.
Mine does the same thing. Took it to a repair shop and they said I needed two motherboards made by NEC for $800 each.
I don't believe them, but am between a rock and a hard place. I'm considering selling/donating the unit for parts, if that is even an option.
Did you find your problem?
Prior to my unit doing what you describe, it would show a clear pic for about 2 hours, then the pic would go very dim. Turning the unit on/off would correct the problem, but 5 mn. later, the screen would go dim again.
Posted on Jun 30, 2008
Sony Wega Plasma 42XS955. Over 2 wks., gradually
I would check the capicitors on the power supply to see if the they are bulging at the top or leaking. I had a Samsung lcd that starting taking and hour to turn on then eventually it would not turn on. So I checked the power supply and saw four bulging capacitors that I replaced and now it's working like new.
Oct 31, 2013 | Sony Televison & Video
Tip
Toshiba 50HP82 Manual Download
Download Toshiba 50HP82 Plasma TV Manual
Would you like to review the features of the Toshiba 50HP82 Plasma TV ?
Have you lost your Toshiba 50HP82 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP82 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP82 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP82 50 in. Plasma Television
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
"please wait thank you for your patience"
Reset the tV to its factory settings. Refer its user manual for more details. Unplug the TV from AC mains wall socket, and replug it after some time, say after 5 minutes or so.
May 23, 2012 | Toshiba V28A000310A1 32HL67U 32 inch...
My Polaroid FLM-2601 will power on to the point where the logo splashes on the screen and then displays the input video source. Immediately following this, the screen flickers rapidly and the speakers...
U have to replaced the whole power board,because the cap that install backward,it cause ur power ICS regulator are dead.U can't buy those ICS,because the tvs compannies only sale thesse ICS only to their sub contractors.
Mar 16, 2010 | Polaroid FLM-2601 Television
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Oct 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Screen goes dark
Fading typically is related to power supply heating or connection opening on the digital drive. You might try fan into vents just to prove this, or plug in outside in the cold, and see how long it is on in test mode.
Dec 17, 2017 | Toshiba 50HP82 50 in. Plasma Television
Polaroid FLM-2601 Television Logo
55 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
