Question about IBM ThinkPad T30 2366 Notebook
Lcd tv shows no video on vga mode?
My lcd (viore 42" edtv), the tv mode work ok but vga mode shows just a quick pip of a video then disappear. also the blue screen of all the modes ( av,s video,componemt1 & 2, vga & dvi ) became black. How to repair or which parts do i need to check?
    Brigadier General:
  • 6,966 Answers
Try lowering the PC's Screen Resolution and Screen Refresh Rate to the lowest possible (800 X 600 @ 60Hz) and work them up a step at a time to your preference. Both can be found at the Settings tab of your Display Properties. Of course, you would still need to press the Fn & F? keys of the laptop to activate external. The Fn key is one of the function keys with a monitor icon on it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 25, 2008
Viore tv troubleshooting
if you get no menu then it might be the lighting control board.
its it bright white but no video then you likely have video board issue .
youll need help. working on the inside will put you eye out
Aug 03, 2014 | Viore 42" 1080p Led42vf80 Lcd Led Hdtv
Video problem pc mode zenith l16v36
Watch my video and I show what your problem is with the VGA/PC input.
Oct 14, 2013 | Zenith Z20LA7R 20 in. EDTV-Ready LCD...
Viore 42 inch tv PD42Vh80 had no sound but great picture HDTV
speakers switched off?
volume on set or a box down or muted? check both the set and box.
Does the set have normal sound when playing a DVD etc via the audio and video jacks on the rear or side?
Apr 29, 2012 | Toymax Viore 42 in. Plasma TV
How do i get my computer to work on my tv
HI,
Your tv does not have a VGA input, so u need a video card inside ur cpu which is able to output composite video. then you can connect the composite video to any of the video input of your tv.
ok
Jan 26, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
I am trying to run pip with x box in the pip and regular comp on main screen but it dosent work the xbox is hi def cables
What inputs are you actually using? If you use VGA as the main display, the PIP feature will work with DVI, 480i (SD) Component Video, S-Video, or Composite video. If you use DVI for the computer's input to the TV, the Component video PIP doesn't have the 480i limit.
Thus if you have VGA from the computer, Hi-def from the X-box isn't going to work. Note: The component video can not be the main screen with VGA input in PIP.
I hope this helps.
Apr 24, 2010 | Gateway FPD2185W 21 in. LCD Television
My viore lcd tv model LC20V21 wont turn on anymore. Any suggestions?
MY VIORE 42NAFC MODEL COMES ON AND SAY PLEASE WAIT AND SHOWS NO PICTURE
Mar 22, 2010 | LG 42LC2D 42 in. LCD HDTV
Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Jun 26, 2009 | Envision L19W761 19 in. LCD TV
Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Feb 16, 2009 | Olevia LT42HVi 42 in. LCD Television
Philips 42PF9946 connect with laptop
Connect to the VGA port on the laptop, using a standard video cable.
Here is how VGA port looks like on your TV:
Note on some laptop you need to activate external video output by pressing a combination of keys, this will swap between laptop LCD video and external video.
Sep 13, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Relisys RLT17AP15
Extract from the manual
Set up PIP function
(must be in VGA mode to activate PIP set up)
20" LCD TV only
If the signal source is VGA
Select the PIP size
Select the Video source
Select the audio source as video or VGA mode
H controls the horizontal size in the second window
V controls the vertical size in the second window
Hope this helps
Stuart
Jun 15, 2008 | Relisys RTL1720 17 in. LCD Television
IBM ThinkPad T30 2366 Notebook Logo
358 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
