Question about Vacuums
How do i change my kirby G6E from the upright hoover to a carpet cleaner
Agent Don
  • 310 Answers
SOURCE: how to use my kirby
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541258
Generic problem for all Vacuums
How to use my Kirby
Posted by rnelson510 on Apr 24, 2008
How to use my Kirby carpet cleaner?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This is kind of a general question and I will try to explain the best I can. Most Kirby’s have a vacuum head and sometimes a shampoo head, the vacuum head is removable on most Kirby’s and the vac head comes off the front for a brushroll and belt change. When you vacuum and you go to adjust the vacuum head, raise the height adjustment all the way u to the top with your foot, then listen to the tone change, @ first you will hear air pulling thru and the brush has not hit the carpet as of yet, that is the sound the you are listening for, once the brushroll hits the carpet – there is a definite tone change and that is when you have it adjusted correctly, try to vacuum with it set that way, if it is picking up well – you’re OK, if not adjust if down one more click. Also remember to do a belt change every 4 to 6 months for good cleaning, change the bag more often because it will pup better with a new belt and bag, or if you don’t have a paper bag, take and scrape the inside of the cloth bag with the scraper provided in the small zipper section. Please refer to the owner’s manual or trouble shooting guide or to your local vacuum cleaner dealer or in the yellow pages, also you can use the Kirby factory or website listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 24, 2008
b0sslady2001
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
SOURCE: I have a Hoover steamvac Dual V carpet cleaner
Corkyron,
Corvetteking is on the right track. However, if the Turbine, which he refers to as the "drive assembly" is locked up, it is possible to remove the screws and clean and lube the 2 bearings inside. The where the fault of my turbine freezing up. A new turbine is about $40 so it's worth the few minutes to open it up, clean and lube it.
If the drive brush, the one with the long square extension, is broken, like mine was, the only thing I have found is to buy the whole brush block at Hoovers.com for about $27. I only need the one drive brush but can't find the part alone.
For a diagram and parts list go here: http://vacuumcleanershop.com/Hoover/Hoover-model-F7412-900.htm
Posted on Jun 24, 2009
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
ftw1952
  • 10319 Answers
SOURCE: hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Posted on Jan 24, 2010
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
Tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby G4 Bagged Upright Vacuum
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
How to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
Mar 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Diamond Edition
If this is a Hoover vacuum, which model is it?
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Upright
Here is a link to my online instructions....
Hope it helps...I also have instruction manuals in DVD and book form.
Marci
Nov 02, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
63 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
