Question about Just Wireless Bluetooth Headset Wireless Headset
I cannot get the bluetooth in pairing mode - Just Wireless Bluetooth Headset Wireless Headset
    Scholar:
  • 81 Answers
Each Bluetooth headset is different when it comes to this, you'll have to check your user guide for the correct combination and timing of buttons. If you don't know where your user guide is, (shame shame!), then try some of the more common ways to get into pairing mode. Hold down the main button until the light flashes rapidly (3 seconds or less between flashes). If that doesn't work, try pressing and holding the main button and the +Volume button at the same time until the light flashes.
Posted on Oct 04, 2010
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Just Wireless Bluetooth Headset Wireless Headset Logo
170 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
