Question about GPS
I replaced the battery in my car. Afterwards, i started the car and checked the head unit. The 'Clarion' symbol came and stayed on. I tried pressing every button but no go. HELP!
    Brigadier General:
  • 3,006 Answers
You have activated the anti-theft mechanism and it's deliberately awkward to defeat or it wouldn't be much use.
First, check all of the documentation which came with the head unit or with the car when you bought it; the security code is often written down or printed somewhere. Also check in the glove boxes as owners sometimes write the code inside them.
If this fails and the head unit was a factory fit item, then visit your car manufacturer's nearest main dealer with proof of vehicle ownership, proof of ID and the vehicle's VIN number ("chassis" number). The dealer can then look up the code; they may charge you for it but most supply them free if you're a regular customer for sales, parts or servicing.
If the unit is not a factory fit item then you can either contact Clarion or one of the many online code providers. Clarion want proof of purchase, independent suppliers just want your money. In either case, you'll need to remove the head unit in order to write down the serial number which will be necessary to look up the code number. Some will just take your money and fail to provide what you need, so exercise caution and only deal with proven trustworthy traders.
Good luck and I hope that you will kindly take a moment to rate my answer.
Posted on Sep 29, 2010
Clarion NZ502E audio problems
The issue has to be with either the head unit or the external amp that is being fed. Reverse the feed to the amp from the Clarion. If the audio issue now shifts to the other side the problem is with the Clarion. If the issue stays the same then the problem is with the amplifier.
Jun 19, 2016 | Clarion Car Audio & Video
Clarion nx 409 touchscreen freezes does not work and sometimes does not display anything. everything still works in the background, tried resetting the unit and disconnecting the battery, only creates a...
my unit ended up doing the same thing. I bought it from a seller on ebay (lessco electronics I believe it was) and it stopped working while under warranty. Whenever I tried to contact the seller he ignored my calls.
To this date I still have not gotten the unit to work again. Very disappointed with the head unit and the seller. I will never buy from him again. AVOID HIM!!!
Dec 11, 2010 | Clarion NX409 Car DVD Player
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
My clarion CD player in my Nissan Primera P12 2004 will not eject the discs can this be rectified and would it be expensive.
Hi.
Check first that it is not a single disk stuck inside.
Try pressing repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
In that case the repair may require replacement of CD drive unit or front panel. When disk does not exject repair done from a local technician may be expensive. Usually better replacing the whole stereo unit.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit, including in-dash stereo. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
Mar 16, 2010 | Clarion Car Audio & Video
Blinking Head Unit After BAttery Jump
check fuse for memory and constant , from behind the deck . red is switched , yellow is constant 12v
Oct 25, 2009 | Car Audio & Video
Need a clarion main wireing off back of stereo
Check Crutchfield.com They have the Replacement Parts for Most of these Head Units. Or Try the Clarion Website under Customer Service. I Know that You can get Pioneer Parts from their Website. It is worth a shot to see if Clarion Does the Same. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 29, 2009 | Clarion DRX5575
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
Unlock Clarion CD Head
use numbers to type in code then press and hold search button till it registers
May 05, 2008 | Car Audio & Video
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
GPS Logo
51 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
