Question about Vivitar ViviCam 8025 Digital Camera
Camera saying memory card locked and i dont know how it locked or how to unlock it. when i push play back it says no file exist.
    Brigadier General:
  • 3,006 Answers
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my answer has been of use and has given you additional options to fix your problem. Please take a moment to rate my reply.
Posted on Sep 29, 2010
I have a L301 compact. it says on rear screen, card locked. what do i do.
he says that becose your memory card is locked p .....if u dont lock it . just put out the memory card and look at rear has a clip...that locks and unlock the card. Olso chek for a switch that locks and unlocks the card on camera if exists..
Sep 21, 2015 | Samsung Cameras
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
When i turn on my camera and i want to take a picture it does'nt let me. it says "this card is lock" and i dont know how to unlock it.
SD cards have a little notch on one side with a yellow tab. This tab can be pushed one way to "lock" the card (so no data can be written to it) or pushed the other way to "unlock" it.
There should be an arrow next to the notch telling you which way is which, but if it's locked right now, push the tab the other way and insert the card again, and it should work fine.
Jun 30, 2010 | SanDisk 2GB microSD Memory Card
Locked memory card...
hi crazytami,
the memory card on your camera is SD. on the side of the card you should be able to see a whitwe toggle switch, try to put it to the left, then try it again on the camera, if not, then try the switch on the right then try it on the camera.
one of them should unlock the memory card. if not, please let me know.
regards,
voodoo
Jun 07, 2009 | Canon PowerShot A460 Digital Camera
CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Mar 03, 2009 | Canon PowerShot A540 Digital Camera
My memory card is locked
my memory card is locked and i dont know how to unlock it
Aug 21, 2008 | Panasonic Lumix DMC-LS70 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Vivitar ViviCam 8025 Digital Camera Logo
120 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
