Question about Hoover Windtunnel Deluxe U54219RM Vacuum
Deluxe windtunnel by hoover
Motor shuts off after a minute of running
    President:
  • 1,673 Answers
Check for a clog in the hose or the dirt inlet by the brush roll. When there is a blockage, the thermo protector will shut the motor off to protect it. That protector could be bad, or a problem with the motor. Is the brush roll turning freely and or is it froze up and won't move.
Posted on Jun 03, 2008
Where do i check for the fuse on my hoover windtunnel vaccum
Most Windtunnels do not have a fuse but have a thermal reset in the motor which shuts the motor off it overheats.
Jan 23, 2018 | Hoover Vacuums
My vacuum got wet, still starts, but shuts off after couple minutes. It also sounds & smells funny.
It may not be safe to use anymore, the motor may be failing from the water intrusion.
Jul 23, 2017 | Hoover Vacuums
Mach 4.7 runs for 2.5 minutes and shuts off
Did you use it to vacuum up fine materials like powder? If you cleaned the filters, but they are original to the machine, replace them. Try changing the bag to a fresh one as well. Beyond that, check how freely the brush turns. If it doesn't turn freely that can but excess load on the motor, if its covered in threads, remove those.
Aug 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel bagless shuts off when warm
it is a heat thermostat in the motor.
contact hoover or a local dealer
Mar 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
Windtunnel shuts off after a few minutes of use.
yes i think i can help. all new hoovers have a thermal motor senser that turns the motor off wen it heats up to a certain point mine hade the same problem so i toke it apart and the bering in the motor was worn and heating up and tripping the senser if u have wd40 put some on the bering and be shure to wipe excess wd40 off so it doesnt get in the wires.
Feb 03, 2009 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover Windtunnel Deluxe U54219RM Vacuum Logo
124 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
