Question about Refrigerators
Broken fridge seal on Liebherr KDves 4632 Index 24/001 How to repair/replace please?
SOURCE: fridge seal repairs
We sell these seals online at http://www.doorseal.com.au
We also have online instructions on how to fit them.
Posted on Nov 12, 2008
  • 108 Answers
SOURCE: Hello- I have an older 24
hmmm... I know the new ones have the freezer on the bottom, if that is the case with yours, I would check to make sure the gasket to the fridge is making a tight seal. A good quick fix is to smear a thin coating of Vaseline (the original kind) on the gasket... as they get older they sometimes get worn and don't make good contact, allowing moist air to get inside and condense. The Vaseline makes it stick a little better.
Posted on Jul 19, 2009
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
  • 4793 Answers
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Posted on Jul 23, 2010
  • 2468 Answers
SOURCE: Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Posted on Jul 30, 2010
Testimonial: "Many thanks for your solution. I will try and take a look but getting to the relays may not be possible without removing the compressor?!!!!"
Hi, we have had a liebherr KI 2444 intgrated fridge/freezer since new, 10 years ago and it has been very reliable. We have noticed an increasing build-up of water gatering on shelves and items, which is...
Most likely condensation caused by a faulty seal. I am in the UK, no idea where you are. Try looking up espares or another spares company in your country.
Apr 16, 2017 | Liebherr Refrigerators
Jul 30, 2010 | Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
I have a Liebherr fridge which seems to be on permanent supercooling. It freezes fluids. I try setting a higher temperature but it just drops back to 4 C
4c is the std operating temp for most fridges.have you checked the door seals for fit if an airleak occurs fridge will try to maintain cooling.....freezing salads.
Feb 11, 2010 | Refrigerators
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Feb 04, 2010 | Liebherr KES4260 Refrigerator
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Apr 22, 2009 | Liebherr K3660-20 Refrigerator
The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the...
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Sep 06, 2008 | Heating & Cooling
Refrigerators Logo
312 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
