Question about Ovens
My Nardi GK95583AX needs new hynges and I am struggling to get some from a local supply and need to buy some on line
How to remove glass from oven door on nardi fea8616
The door is in two halves, you must remove the door seal and then the screws to take the door apart and replace the glass..
Jan 15, 2017 | Ovens
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Nardi oven F86
I have a Nardi f86 but I Don't know how can I used the Bud ( knob ) of the furnace, please can you help me, thanks verf much, greetings of ANNE
Jun 03, 2013 | Ovens
Buy parts
if you need to buy parts for your oven - you can get the parts at your local appliance repair shop or appliance supply store. just take the parts you need in to the store plus the make,model and serial number of your unit and they will either have them in stock or will be able to order them for you.
c...
Feb 19, 2011 | Ovens
Hinge snapped on Nardi EK95583AC Range cooker
I have the same problem and am about to replace both hinges and hinge runners (http://shop.ukwhitegoods.co.uk) recommend you should replace both hinges as if one is gone the other will follow soon. The section on the hinge gives a good account on how to replace the hinges safely and how to get to the runners that may need getting into the inside of the oven by removing the sides. I havent gone through this yet so cannot honestly give any more advice other than whats out on the web.
If you follow this link please:
http://tinyurl.com/djntxb
The parts you need are listed there for you. Part numbers 031118009907R and 031199009903R
Adamski
Apr 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Nardi FE46 electric oven short
it appears that there's a short in the oven. When you turn it on is when the short happens and in order to properly determine what is wrong then you are probably have to call a service tech./
Dec 23, 2008 | Ovens
Ovens Logo
242 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
