Question about Polycom SoundPoint Pro SE-225
The main speaker is hissing quietly at all times when the power is plugged in. Is connected properly and the phone is working correctly other than this issue - any suggestions, or is this a manufacturers fault?
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
APX400.4M. 12 volts on.... Power LED on....fuse OK...but no sound...not even a hiss from the speakers
Make sure that your speaker cables are connected properly and that the amp is not in protection mode. Also make sure that the amp ground wire is connected solidly to the vehicle chassis in a paint-free location. If you do all of that and it still doesn't work, make sure the head unit lead is connected correctly to the amp (these should be RCA cables).
Feb 27, 2011 | Clarion APX400.4M Car Audio Amplifier
My amp isn't producing any sound. It works when headphones are in but that's it. Please help
The headphones socket is on the preamp stage - it works so the problem must be after the pre-amp.
Do you get any sound at all from the speakers (hiss or perhaps a click) when you turn it on?
If yes it is an amplifier problem.
Here are some possible causes
  • A wire has come off the loudspeaker - easy to fix
  • Speaker protection fuse has blown - small glass fuse mounted on main amplifier chassis - replace with correct rated and type of fuse (note some of these are 'slow' blow type - important that you get the right one)
  • faulty component in the main amplifier stage - requires attention from qualified repairer
  • Loudspeaker burnt out - this can be tested by connecting another speaker across the terminals of the built in speaker.
  • The headphone jack socket automatically disconnects the loudspeaker when phones are plugged in - it could be that the contact in the headphone jack socket is bent and not re-making contact when the headphones are unplugged.
Feb 26, 2011 | Orange Crush 15r 15w Reverb Guitar...
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Rear wireless speaker ticking noise
I noticed the ticking noise stops if the rear wireless unit is powered on after the main receiver. If the main receiver is on first, then the rear powered up, there is no ticking. This is pretty retarded though since I want to leave my rear receiver on all the time and power down the main unit when not in use.
Apr 25, 2009 | Audio Players & Recorders
Left speaker terminal on the sub doesn't work properly
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Jan 15, 2009 | Logitech Z-2300 Computer Speakers
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Polycom SoundPoint Pro SE-225 Logo
63 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
