Question about KitchenAid Ovens
I need a manual for a KitchenAid oven model 6KA0100 IN. I've searched online but can't find any model numbers starting with 6KA. I'm not sure how old the oven is, it's in a newly bought house.
aborcass
  • 2651 Answers
SOURCE: need deminsions to purchase new oven
every oven has different dimensions, the easiest and best thing to do, is to slightly pull unit from the cabinet its installed in and measure the max. opening both height and width.--- if its a freestanding range that you are talkin about the dimensions are standard inches,, 20-24-30-36.
Posted on Dec 15, 2008
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
rtpflh
  • 546 Answers
SOURCE: No manual to Kenmore electric oven 8+ years old
if the glass bulb cover has a 'wire' across it that's the spring clip that holds it in place.pull clip down or aside to remove cover,unscrew bulb as you would any other.if it doesn't have aforementioned clip.try to rotate cover counterclockwise to disengage 'ears' from 'slots',similar to the the way a blender fits the base.look under cook-top,above oven door for the lock lever that must be pulled out [engaged] for self clean to work.
Posted on Oct 11, 2009
  • 30 Answers
SOURCE: The model number on my kenmore ovens owner's
Don't replace anythingf, try this! The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved.
Posted on Nov 24, 2009
SOURCE: i need a bellissimo oven manual
I to have brought a house with this oven and I am sure i am not using it properly, how did you go with instructions. Roz
Posted on Dec 09, 2010
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28³??" (73.0 cm) H x 26³??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
I need the manual for a PC 25355 model convection oven Not sure how the temperature controls work?
Hi Rosa,
You really needed to search online for this. Use search string "user manual for pc25355" which gets you to here:
Free Kitchen Appliance User Manuals ManualsOnline com
Jul 26, 2015 | Ovens
Where do I get a fan element from?
You don't say what oven it is but if you go online to ebay or type in your make and model then a number of appliance sellers will pop up and search through them. Its not a major job to change the element, make sure the cooker is isolated at the main switch. Someone with basic DIY skills and a modest toolkit should do it no problem. You will need the machine data off a sticker that's usually on the back of the machine. Make sure the replacement matches the current one exactly. You will find that element may fit a range of ovens, check the machine serial numbers carefully. If you have the original purchase paperwork there is usually a panel in the back with duplicate numbers so look there first.
May 22, 2015 | Ovens
I need a kitchenaid superba manual freestanding electric oven manual model number KERC607HWH0
Kitchenaid has manuals for most of their appliances on their support web site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Enter the model number and the type of customer you are (consumer) in the drop down menu and click on Go. The direct link to the manual for the KERC607HWH0 electric range is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209753846.pdf .
I hope this helps.
Oct 19, 2011 | Ovens
I just got a Rosieres F200T oven for free but don't know what the degree knob means since it is numbered 1-9 and not the actual temps that I am looking for. I was searching online to see if anywhere...
Hello, Timcampbell82 -
I have tried to find a user's manual for a Rosieres F200T oven for you. I suspect the user's manual states what temperature each of the numbers for the degree knob represent.
So far, I have not found a manual online for you. I did find an online forum in French, with mention of a manual for the oven model, but the messages date from 2008:
https://www.meilleurduchef.com/fr/forum/notice_materiel/1225015073-14054-650
You may wish to locate a business in your area which performs repairs for Rosieres ovens and ask if they can find a manual you can purchase for your model oven. Or, perhaps one of the repair technicians can tell you what temperature each number represents.
Best wishes.
Jan 19, 2018 | Ovens
Have oven model no. 6KA0100, installed in our new home eleven years ago. Wife complains oven takes long time to reach set temp. I note that the oven door is always slightly ajar at top as compared to...
I would say your stove is old and the door closer springs are burnt out and shot. Yes if the door is open even a little bit the stove will not heat up. If the temp is not right the cakes will not bake right. Get a new one. or get a repair person to fix it. It will keep your wife happy.
Aug 27, 2017 | KitchenAid Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
I have misplaced the manual for my oven and I need the self cleaning instructions. Model # RF365PXDQ0 Serial # FE2007966
First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
The manual is available here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203189075.pdf . If the direct link doesn't work, start here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number and then click Go.
I hope this helps.
Apr 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
From KitchenAid themselves
F3 E0
Get one from the people in the first video. Very easy fix.
https://www.youtube.com/watch?v=VZKHpduF9RI
kitchenaid oven temperature sensor replacement Google Search
Sep 17, 2009 | KitchenAid Ovens
Ovens Logo
50 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
