Question about Scanport GL-1920S 19" Flat Panel LCD Monitor
Help. I'm attempting to plug in my GEM GL1920S monitor and I can't figure out where the power cord gets plugged into the machine. Perhaps I have the wrong one. I seem to have a standard plug. thanks
  • 11,361 Answers
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
I am looking for a power plug for my gem monitor #LCAO1F D3350382G
On eBay or Google Product Search or Amazon, search
GEM GL-822 power
or
GEM GL-822 12V 5A
There are a number available there. It is 12V DC, 5A
Apr 19, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Hello i bought WHITE SEWING MACHINE MODEL 3900F DONOT HAVE A CORD FOR IT--OR EVEN KNOW MACHINE WORKS SO I HAVE NOT THE FOOT CORD OR POWER CORD TO PLUG MACHINE IN--THERE IS A 3 PRONG TO MACHINE---THREE...
Search for:
Make Model parts
You can probably find one (perhaps sites like eBay) where there are generic parts. Just be sure to make sure the plug on the machine matches the plug on the cord you purchase. There are multiple shapes and designs of plugs available, so compare the pictures with your machine.
Feb 28, 2018 | White Sewing Sewing Machines
I have a toshiba satelite p2050-57802 laptop and im trying to figure out how to hook up monitor to laptop. Screeen got broken on laptop and misplaced manual. Can you help please ?
There is a monitor connection on the back of the pc, next to the ac adapter connector. Just plug in your monitor to it and make sure you plug the monitor's power cord into an electrical wall outlet.
Oct 06, 2010 | Computers & Internet
Monitor keeps turning off but power says it's still on
You are OK with the power cord, more likely to be failure in the power supply/Inverter board, look for bad fuse and shorterd transistors, see Dell pictures here: http://s807.photobucket.com/home/budm/allalbums
Transistors should be checked out off circuits.
Mar 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Lost AC plug-in power cord. Is it possible to
What fax machine?. if it looks like a computer power cord plug, that's what you need.
Feb 23, 2010 | Office Equipment & Supplies
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor
Monitors need power cords to function, & there is nowhere near enough power in the data cable to power the monitor. So, it sounds like the power cable got pulled out somehow and is now lying on the floor. The power cable will be a small plug like you have on a radio or other similar devices instead of the standard sized plug that older monitors have. Once you plug the power cord back in, it should be fine.
Jul 01, 2008 | Microtek C783GM 17" Flat Panel LCD Monitor
Moving Horizontal Lines on LCD Computer Monitor (Windows XP2)
It is possible that what you are seeing is 60 cycles AC hum, but then again it may not.
Perhaps you can try increasing your Screen Refresh Rate to any other setting other than 60 Hertz. (Display Properties/Settings/ Advanced/Monitor)
If that does not work, you may need to check your wirings and/or the power supply of the monitor with particular attention to the filter/power capacitor.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Dec 09, 2007 | Computers & Internet
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Scanport GL-1920S 19" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
