Question about Bose TriPort Consumer Headphones
How to fix broken cable? thanks - Bose TriPort Consumer Headphones
  • 64 Answers
If it is still under the warranty. Try contacting Bose support. If its not, then where out of luck. Bose parts are expensive. But you may visit radioshack for wires similar to the one you have and then have it fixed by a local technician or electrician.
Posted on Sep 29, 2010
How do you fix your broken down wheels in the middle of nowhere but you do have your emrgency kit and fixing kit ?
I learned by experience. When something breaks down, I learn to fix it for when it breaks down the next time. On a bike, the parts most likely to break down are a flat tire and a broken chain. Carrying a flat repair kit and a multi tool to fix a broken chain is feasible. You can break a wheel spoke. This you can't fix in the field but you can compensate by learning which spokes to loosen/tighten adjacent the broken one to get you home/shop. You can break a brake or derailleur cable. A spare cable is light and easy to carry but it is very time consuming to replace in the field. Depending on how far you are from home, it may be easier to ride home with a broken cable. Preventive maintenance is the best way to avoid broken cables and/or chains - replace them every 3 years or so, depending on usage and wear/tear. Other broken parts, you will have to assess in the field. You may have to walk home or call a friend to pick you up.
Sep 25, 2014 | Cycling
Keyboard Broken?
two things it could be, first, yes broken and second the ribbon cable under keyboard are not in place
Oct 17, 2013 | Samsung NP-N130-JA01US Netbook
1988 dodge hood release cable diagram
go to www.automecanico.com translate this website with your browser , get the topic and fix it.
God bless you
Jul 28, 2013 | Cars & Trucks
I have a Honda Solo 250cc. The spedo and KM counter has stopped working. How do I fix it? thank you for your help
The cable may be broken inside. First I would remove the speedo clock and undo the cable that goes into the back, unscrew the nut anti clockwise and pull out the cable, it may have snapped at this end or at the other end where it goes to the front wheel. if its not snapped push the bike forward and note if the shaft is spinning. if it is not then it is broken. Trace the cable down to the front wheel and there will be a similar fixing going into the hub of the wheel, unscrew this and check that the shaft in the cable is broken or spins or not. I think you will find that the cable is broken at either of the ends. Hope this helps. Alex
May 17, 2011 | Honda Shadow Custom 400 Motorcycles
ABS light came on, on my Polo, garage ran a diagnostic, it shows an open circuit which points to a broken cable or faulty plug. Have been told to take it to an auto- electrician, can anyone...
If it's a faulty plug or broken cable then the only way to fix that is to literally dismantle the car's dash and inspect every single one of them - this is going to be a very long job, it's better to leave it to a pro.
Sep 27, 2010 | 2002 Volkswagen Golf
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
Cable snapped out of back of tv?
Hello stacystea
Most likely your not going to be able to fix it most of the cables are soldered on and you'll have to know where it goes so if it just snapped out then you'll have to take it to someone who can fix it for you because also opening the tv could damage it more
Thanks
Apr 16, 2009 | Sharp Televison & Video
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Open Questions:
Bose TriPort Consumer Headphones Logo
299 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
