Question about Photography
I have installed the driver for my Yashica PS-500 photo scanner but when I plug the scanner in it tells me: The drivers for this device are not installed. (Code 28)
  • Obertelli
    Obertelli Sep 29, 2010
    Which operating system does your host pc use?
clark_styx
  • 282 Answers
SOURCE: DRIVERS FOR DELL XPS M1210
you need the ricoh chipset drivers
Posted on Aug 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: phillips gogear 6025 is not recognize by computer, code 28
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
  • 12 Answers
SOURCE: Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Posted on Mar 21, 2009
SOURCE: Driver installation error code 28 inf error
im receiving a error inf 28 on my mp3 sony walkman nwz-e344
Posted on Nov 03, 2010
  • 10406 Answers
SOURCE: pci simple controller comunication not installed
The "missing" device-drivers could either be:
* a dial-up modem,
* a network-card,
* some serial device, e.g., some USB (Universal _SERIAL_ Bus) hardware.
Access: http://WindowsUpdate.Microsoft.com
Click "Custom" scan
When it completes, click "Optional Hardware",
to see if Windows Update is offering a device-driver.
Posted on Jan 23, 2011
Scanner A3USB is not recognizing in vista. What should i do to fix this problem.
Make sure the device is not plugged into the computer during the drivers install. After all the files are installed plug the device into the computer. DO NOT PLUG DEVICES INTO "FRONT" USB PORTS ON THE COMPUTER AS THESE ARE "HUB" PORTS AND the system may not "see" the device.
download drivers by clicking here ---> web.EXE
install them then plug in the scanner when it tells you to
Apr 13, 2011 | Mustek A3 USB Flatbed Scanner
Epson stylus photo rx500
You need to download the drivers again
Apr 14, 2008 | Epson Stylus Photo RX500 Printer
Please i need the drivers canon scan n 650u for windows vista ultimate 64 bit
Download the XP driver for the Canoscan N650U scanner and save it on your desktop. Once the download is finished go to your desktop and unzip or unrar it and then plug in your scanner and try installing it - let it fail. Then, go into your control panel, device manager, find your scanner - right click "update driver software" go in and tell it where to look - here is where it tells you the driver isn't encoded properly but it gives you the option to install it anyway and it works just great - it'll re-organize in your device manager under imaging devices when done.
-kudos goes to "expertz" from techarena
Jul 31, 2010 | Canon CanoScan N650U Flatbed Scanner
I want to install the driver of my scanner Mustek 1200 UB, for xp, please help me
First, go to:
http://www.mustek.com/mustek/supportdrivers.php
Under "Category," select "SCANNER."
Under "Series," select "USB Port."
Under "Model," select "1200 UB."
Driver installation instructions for XP/Win98/SE will be shown.
For Windows XP, there are 5 separate files you will have to download (the instructions tell you this).
Also note: "Make sure the device is not plugged into the computer during the drivers install. After all the files are installed plug the device into the computer. DO NOT PLUG DEVICES INTO "FRONT" USB PORTS ON THE COMPUTER AS THESE ARE "HUB" PORTS AND the system may not "see" the device."
Good Luck!
Jan 24, 2010 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
I purchased a VuPoint C500 VP photo scanner. I've
Delete the software
Re-install but do not plug the USB cable in until the software tells you to.
Dec 29, 2009 | Office Equipment & Supplies
My dell studio comp does not allowconnection ?to epson 2480 photo scanner?
pls try to check your cable connection. test it with another device using the same usb interface, if it work with that, then there you can conclude if there is an issue with your scanner.
2nd check if you have properly installed it. unlpug and uninstall the scanner program then before plugging it black reinstall the scanner program. this usually clears out the conflict of plugging before installing the driver.
Sep 14, 2009 | Epson Perfection 2480 Color Photo Scanner
Epson Perfection 1660 Operation Problem
Possible driver issue.
Please trash and re-install the drivers.
Drivers are available for download at the epson.com site.
Apr 29, 2009 | Epson Perfection 1660 Photo Flatbed...
Yashica da5000 mp3 player installation disk lost
MY YASHICA MP3 DA-8000 INSTALLATION CD LOST
Apr 03, 2009 | Audio Players & Recorders
No drivers found
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
If it is not installed properly and working there should be a yellow triangle with an exclamation mark inside it next to the scanner name.
Whatever it says, right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready to use, re-install the scanner driver do not plug in the scanner yet!.
Once it has finished installing, re-connect the scanner USB lead.
Windows should install the drivers and tell you the scanner is ready to use.
Apr 24, 2008 | Canon CanoScan 4400f MultiFunction Color...
Photography Logo
152 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
