Question about Jenn-Air JXT8030ADS Kitchen Hood
Flood lights will not turn off
The two flood lights on my Jenn-Air hood will not turn off. I can dim the lights, but when I press the button again it they resume full lighting. Any suggestions? Is the ballast out?
  • Anonymous Mar 01, 2009
    Flood lights would not turn off.  Had to unplug the unit from the connectors behind the filters.  Once you unplug and plug the unit back, the lights and fan will work.  If you leave it on or turn off the light switch, the flood lights will turn on automatically on low without the ability to shut them off.  To turn it off, you have to unplug the wires again.
  • general333 Mar 23, 2009
    My lights will not turn off either on my Jenn Air hood
5 Suggested Answers
  • 26 Answers
SOURCE: Jenn-Air 48600 touch button problem
You probably need a new touch pad membrane
Posted on Jan 09, 2008
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
  • 142 Answers
SOURCE: Oven light won't turn off
It sounds to me like the switch that operates the light is malfunctioning. You're taking the right steps by pressing the switch by hand. Since that didn't work, either that switch is not working or there is another switch that is intended to keep the light on while the door is closed. You can look at that one too. The last thing to consider is if the light is relay controlled, the relay might be stuck closed and applying power to the light all the time.
Posted on Mar 09, 2008
manhandy
  • 146 Answers
SOURCE: JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Posted on Jul 05, 2009
What could make my 1993 geo tracker flood 1.6
the G16 engine, floods.
there are 2 engines, G16a and b.
8valve TBI and the 16v MPI engine.
(EFI on both are radically different.)
this pages shows all 3 levels of diagnosis
3 causes. physics.
14 causes.
and then the full list.
http://www.fixkick.com/flooding.html
to find the cause takes tools.
got tools?, what to buy them.?
or just guess.?
here ill guess (useless)
1: the FPR reg is stuck closed, and fuel pressures 2x normal an it floods.
got 50 more...
post a photo of your engine and WIN>
get the first of millions, to do it.
amazing at it seems...
learn that almost all cars have
engine options
and transmissions.
May 05, 2016 | Geo Cars & Trucks
I have a EIDW6105GS1 all of the light flash! it did it once before and I thought I reset it somehow! but I cant remember! can you help?
There might be a possibility of resetting by pressing High Temp button 5 times. But I don't think this may solve the problem.
All lights flashing could mean a flood detection. This means water is leaking into the base of dishwasher. The flood switch has to be dried to make it work again. Also need to find the source of the leak. Make sure dishwasher is disconnected from mains power before attempting to work in it.
Apr 25, 2014 | Electrolux Dishwashers
I ran out of gas, stupid i know ( my husbands going to shoot me) Is there a quik fix to getting to start now. It has gas, but of course the fuel injection is messed up now.
hi try some injection cleaner...like redX or something like that, this should clear the injectors and get the fuel flowing, just a tip, now it has fuel in, you want to press the gas peddle all the way to the floor and turn it over don't pump it just hold it down with your foot( turn key in ignition that is lol ) this will help "flood" the system with fuel and help it start better...by the way, when i say flood, that's just loosely termed flood, it dose not actually flood it, just puts a little extra fuel into the pots....hope this helps please comment and rate thank
Feb 03, 2011 | 1994 Jeep Grand Cherokee
Our Jenn air fridge is a few yrs old. A few
ok stop the water // the water valve is bad..very bad . change it ..its a dual valve in the back . right where the lin is hooked up . this will correct problem .. **** hope this helps . i think it will .. / feed back pls ..
Jan 12, 2010 | Refrigerators
How to light pilot for oven in 1950's roper delux
If it is an insta-light, I just rebuilt a Roper that age, the instructions are to turn off oven heat control, wait two minutes, locate red button which you have done, apply match to pilot, depress red button for 5 seconds and that should keep pilot light on, the instruction manual states to hold match for 60 seconds prior to pushing button, then hold for 5 seconds, either way, you don't want to flood the area with raw gas, and yet still apply enough heat long enough to lock in pilot, has the gas line been loose? Make sure it is purged of air, again, don't flood area with raw gas, it is pretty typical pilot procedure, the worst part is finding the red button, usually behind a burner cover. So try holding the button a bit longer with your match on it, some take a while, worst is the control has gone bad, but there are replacement valves for this vintage, I did check,
Sep 21, 2009 | Roper Kitchen Ranges
Flood light has faint glow at all time
Sounds like you have the Dual Brite on, the dual brite is low level accent lighting. Check to see if you have this switched on, if so turn it off.
Mar 12, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
Jenn-Air JXT8030ADS Kitchen Hood Logo
304 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
