Question about LG WD-3243RHD Front Load Washer / Dryer
I have an LG WD-1457RD washer/dryer with a cracked drain hose. After about 4 years the hose wore at a curve about half way along it's length. Unfortunately it's too short to cut there as it won't reach the sink. I would like to either splice the hose or change it myself. Option 1 would work but I can't seem to get my splice to hold, would a small piece of connector tubing with hose clamps work the best. In terms of replacing the hose, I can't seem to figure out how to get access to where the hose attaches inside the machine (front right corner behind the filter panel). Is there an easy way to get to it? Is it like the LG WM3677 at this link http://www.fixya.com/support/t1416783-lg_wm3677hw_pump_problem ? Thanks so much. Adele
  • adele_pile Sep 29, 2010
    Hi there, yes I feel this is insufficient. Having me pay $20 to point me to a web site to download a manual for an additional fee does not answer my question. I am familiar with web sites where you can pay to get the manual but elected to try and get help here first.
    Kindest regards,
    Adele
  • 11,896 Answers
I would use hose clamps. That will hold really good. The drain hose attaches to a plastic piece on the pump housing. Water inlet hoses attach to the water inlet valves.
You can go to partselect . com or repairclinic.com and view free diagrams
Posted on Sep 29, 2010
    President:
  • 1,932 Answers
You can download the service manual from below website for your LG WM3677 and it will help you a lot to replace the hose.
http://www.s100-manuals.com/manualdetails.asp?id=211954
Thank You
I have an LG WD-1457RD washer and dryer and it shrinks all of my clothes, Possibly Temperature problem?
Very few driers have temperature controls. The best way to stop this happening is to run it for less time. Take the clothes out when they are still very slightly damp. If you hang them up straight away, you will find that most wont need ironing. Some dryers allow you to set the amount of moisture in the clothes when they shutoff, but they generally are the most expensive ones.
May 16, 2016 | LG Washing Machines
LG WD 1457RD washer dryer will no spin stops on 14 with OE alarm have cleaned filter etc still not working
pull out plug
check the pipe from the drum to the pump it may be blocked??
or your pump needs to be looked at
Dec 14, 2013 | Washing Machines
How do you unclog drain hose?
Remove the drain hose from the standpipe and the back of the machine and use a long rod or broom handle and push it through the hose.
May 26, 2012 | LG WD-14124RD Front Load Washer / Dryer
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WD-3243RHD Front Load Washer / Dryer Logo
144 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
